Thread: Noise when starting the car which goes away after a few seconds
Results 1 to 10 of 10
  1. Noise when starting the car which goes away after a few seconds
    Jun 2012
    Leicester
    Hi all,
    Occasionally when I start the car I get a rattling sound from the engine area
    I have put up a video clip on youtube VW golf 1.4 tsi 2009 noise when engine starts - YouTube
    I have been notified that the shocks need replacing, otherwise it drives fine. Could this be related or a different matter?
    Any ideas what it could be?
    VW Golf 2009 59 Plate, 1.4 TSI Petrol
    2009 MK6 Golf 1.4 TSI SE 122PS Manual
  2. Re: Noise when starting the car which goes away after a few seconds
    May 2008
    London, UK
    Will be the timing chain and not cheap to replace unfortunately
  3. Re: Noise when starting the car which goes away after a few seconds
    Jun 2012
    Leicester
    Thanks, so unlikely nothing to do with tappets?
  4. Re: Noise when starting the car which goes away after a few seconds
    Huddersfield, West Yorkshire.
    Are they on timing chains? I have a diesel which is on a belt, but i didn't really think VAG cars came on chains ever.
  5. Re: Noise when starting the car which goes away after a few seconds
    Dec 2010
    I think mk6 Golfs with the TSI petrol engine have a timing chain; diesels have a timing belt.
    The problem seems to be with the timing chain tensioner. If you Google 'VW tsi engine timing chain tensioner failure' you find loads of information. Some mk6 GTI owners over on Golf GTI forum have replaced their timing chain tensioners as a preventative measure - there's lots of information on that forum about this issue.
    Golf GTD; Carbon Grey, 18" VW Rotary Alloys in Anthracite, Bi-Xenons, RCD510+Dynaudio, Parking Sensors, Luxury Pack and 3 Year Service Plan
  6. Re: Noise when starting the car which goes away after a few seconds
    Dec 2012
    Bury Lancs
    [QUOTE=discobarry;909132]Are they on timing chains? I have a diesel which is on a belt, but i didn't really think VAG cars came on https://www.vwaudiforum.co.uk/forum/s...ine-Reliabilty
    2010 Golf 2.0 TDI GT 140 DSG , 5 door in white.
  7. Re: Noise when starting the car which goes away after a few seconds
    Jun 2012
    Leicester
    i know that petrol is on a timing chain, why would the timing chain make a sound for a few seconds and then settle thereafter?
    after watching the videos on here http://www.adamlewin.co.uk/vw-mk5-go...chain-problem/
    the sound I get from the engine sounds exactly the same as this video > the https://www.youtube.com/watch?v=S6L3fF49OT8
    especially after turning the engine off and then on again the noisy sound doesn't come back again
  8. Re: Noise when starting the car which goes away after a few seconds
    Dec 2012
    Bury Lancs
    If the oil is draining out of the hydraulic tap pets when the car has been stood a few hours, you get a load tappet noise when the engine is started from cold, after a few seconds the oil pressure refills the tappet and silences things down again. As said the timing chain noise would be constant I would have thought..
    live heard it on other cars years ago, but haven't had it personally. Hope you manage to get it sorted.
  9. Re: Noise when starting the car which goes away after a few seconds
    Dec 2010
    Quote Originally Posted by ssaini View Post
    Probably worth a read of this, which explains it much better than I can.
    GolfGTIforum.co.uk - An independent forum for Volkswagen Golf GTI enthusiasts.
  10. Re: Noise when starting the car which goes away after a few seconds
    May 2008
    London, UK
    It's definitely the chain causing that noise, I had the same problem round about this time last year. If you leave it like that the risk is the chain will jump a cog and wreck the engine.
  1. Rattle for a few seconds on starting - not Tappets
    By amatty in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-02-2014, 06:19 PM
  2. Beeping Noise when starting Car
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-03-2013, 10:51 AM
  3. Replies: 5
    Last Post: 26-06-2012, 08:25 PM
  4. First few seconds after starting
    By Happygilmore78 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-01-2012, 02:41 PM
