Thread: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
Results 1 to 10 of 10
  1. 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    Dec 2010
    Wiltshire
    Any ideas? I thought issues were sorted but my mate said it's ongoing issue with 2.0TDi?
  2. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    46 Post(s)
    From doing a quick google it seems the hex design is still there but totally re-designed.
    That was the first page I seen on the results so do your own research as someone might say different.
  3. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    Mar 2009
    Montenegro
    13 Post(s)
    According to my searches on the net, I found that car produced from 2010 are safe. I found few posts where they have complained even on 2009 models with CR engines (it was A4 with 2.0 TDI). I am looking for some good A6, but unfortunately, I cannot afford A6 from 2010.
  4. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    Dec 2010
    Wiltshire
    I spoke to someone today and was told that all 2.0tdi affected. Bloke said he installed upgraded pump to 61 plate 2.0tdi. I also spoke to VW Audi specialist in London and they said they had 2010 car with engine failure due to pump failure.
  5. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    46 Post(s)
    Probably to do with crappy longlife service intervals just like everything else.
  6. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    Mar 2009
    Montenegro
    13 Post(s)
    I think also that longlife service intervals are reason of many failures. This longlife shorts engine's life for sure!
  7. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    Mar 2009
    Montenegro
    13 Post(s)
    Quote Originally Posted by crazy4alfa View Post
    It is obviously that as time pass there will be more and more failures with newer cars (2010,2011) regarding oil pump. I know that as soon as I buy A6 2.0 TDI I will put some money on part to check / replace oil pump.
  8. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    Dec 2010
    Wiltshire
    I spoke to VW/ Audi specialist and was told that best mod is to put old style 1.9tdi PD oil pump which should last forever.
  9. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    Dublin, Ireland
    I wonder is it the oil pick up filter that gets clogged and in turn makes the oil pump seize etc.
    I replaced a pick up filter in a 06 A4 last year.A lot of carbon particles in the bottom of the sump.
    Noticed when I was changing the oil in my A6 that there was some carbon particles at the bottom of the waste oil bucket. Wonder is this the reason oil pumps are failing ??
    A6 2.0 tdi Auto 2008 Facelift.
  10. Re: 2.0TDI common rail are they affected by oil pump balancer shaft failures?
    Dec 2010
    Wiltshire
    Pumps are failing cause the connecting shaft fails.
  1. A4 avant 2.0tdi BRE engine balancer shaft issues?
    By scfc_151 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-05-2016, 05:11 PM
  2. 2009 audi a4 2.0tdi 143bhp oil pump shaft
    By Matt.russell in forum 2.0TDi - Engine
    Last Post: 22-11-2013, 09:49 AM
  3. Attention Audi A4 oil pump / balancer shaft
    By Don't like Audi in forum Chat - Anything with wheels
    Last Post: 03-02-2012, 09:56 PM
  4. 3.0TDI Bosch 0455 010 090 common rail pump
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-09-2010, 05:13 PM
  5. Oil pump balancer shaft
    By mission66 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-08-2010, 08:10 AM
