Thread: Steering Wheel Shudder/Vibration
  1. Steering Wheel Shudder/Vibration
    Jan 2014
    Northern Ireland
    Seems to be quite noticeable at speeds over 70mph although there is a slight vibration more often than not all the time but quite faint. Ive just read a similar post by a French guy who states his problem turned out to be faulty Drive Shafts? ?I know my 99 needs rear axle bushions, surely unrelated? Is there bushions in around the front steering arms and/or track rod ends?? I doubt it's a serious issue but i'd like to get it sorted as soon as.
    cheers for any advice in advance!
  2. Re: Steering Wheel Shudder/Vibration
    Dec 2009
    Have you checked the following:
    1. Wheel balance all round - maybe you've thrown a wheel weight
    2. Check at the same time that you haven't bent a wheel - I had endless problems when i bought my passat. It had replica RS4 18" wheels and they were all bent and out of shape.
    3. Check you track rod ends - grab each wheel at 3&9 o'clock positions and see if you can waggle the wheel (in the same direction/manner as the steering would turn). I had a buggered track rod end on one side and it gave me intermittent vibration at different times/speeds as the ball joint was knackered.
    4. Have a look at the top and bottom arm bushes for excessive movement. (you may need to take it to a garage or mot tester for this one)
    As for drive shafts I'm not sure.... had both mine replaced recently and I thought the had in the past caused some wobbling but that may have been from any of the above mentioned things. Would certainly check those first before diving into expensive shaft replacement.
    2002 Passat PD 130 TDI Sport Estate
    2003 Golf GT TDI PD 130
  3. Re: Steering Wheel Shudder/Vibration
    Jan 2014
    Northern Ireland
    Cheers mate, i will certainly check all those when i get 5 tonight lol Thanks again buddy.
  4. Re: Steering Wheel Shudder/Vibration
    Jan 2014
    Northern Ireland
    Stuck a set of 18" RS8s on here yesterday and to be honest the previous vibration is next to non existant. Will still get everything checked. Nice wee remap done yesterday too, increase of 50lb per foot of torque and easy 35+bhp increase. 90bhp standard, feels at least 120bhp now. Lovin it
  5. Re: Steering Wheel Shudder/Vibration
    Dec 2009
    Quote Originally Posted by B5-Passat-1988 View Post
    Glad thats sorted it then!
  1. steering wheel vibration
    By DSGboy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-05-2015, 11:49 AM
  2. steering wheel vibration.
    By jon78 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2014, 08:39 PM
  3. Question Steering wheel vibration
    By WOLFSBURG-PD in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-02-2014, 06:10 PM
  4. Replies: 7
    Last Post: 30-06-2011, 11:12 PM
  5. steering wheel vibration
    By ian in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-02-2007, 05:22 PM
