Thread: Problems With Abs Pressure Sensor
  1. Problems With Abs Pressure Sensor
    Sep 2007
    I HAV A CUSTOMERS CAR IN WHICH IS A AUDI A2 ON A O2REG 1.4 PETROL.
    THE ABS SYSTEM IS PLAYING UP ROYAL AND NO BODY CAN GET TO THE BOTTOM OF IT. I HAVE BEEN GETTING A CODE OUT OF THE ECU TELLING ME THAT THE ABS PRESSURE SENSOR IS FAULTY , THE TROUBLE IS IT ALL SEEMS TO BE IN THE PUMP AND ECU ON THE PUMP ,IS THIS TURE OR IS THERE ANOTHER SENSOR I HAVE MISSED. CAN ANYONE HELP
  2. Re: Problems With Abs Pressure Sensor
    134 Post(s)
    2009 Post(s)
    What fault code number?
  3. Re: Problems With Abs Pressure Sensor
    Sep 2007
    Not Sure I Can Remember Somthing About G50
  4. Re: Problems With Abs Pressure Sensor
    134 Post(s)
    2009 Post(s)
    Can you read it again tomorrow and post it?
  5. Re: Problems With Abs Pressure Sensor
    Sep 2007
    Yeh Will Do Thanks For The Help
  1. VW Golf Mk4 1.6 6v - Oil pressure problems/Random battery cut
    By paresh0407 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2009, 10:53 PM
  2. PASSAT Alarm and reverse sensor problems
    By Intake in forum Passat - Archive Topics
    Last Post: 26-06-2007, 09:33 PM
  3. Thrust Sensor same as Map Sensor?
    By whistleblower in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2007, 06:03 PM
  4. help - yaw sensor problems
    By samclark in forum Beetle 2000-
    Last Post: 18-04-2007, 12:24 AM
  5. air mass sensor problems
    By keithg in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-11-2006, 06:52 PM
