Thread: Blower fan noisy, any ideas? noise coming from engine bay?
  1. Blower fan noisy, any ideas? noise coming from engine bay?
    Feb 2012
    Lincoln, United Kingdom
    Hi guys, the wife noticed that there is a whirring noise coming from the fan when the air con is running.
    I've tried it myself and its definitely there, however it's pointing me to the blower rather than the climate control. I'm assuming this, because it is there without the engine running, therefore the compressor wouldn't be on. I checked the pollen filters and they don't look too bad.
    I've also opened the bonnet and noticed that the noise seems to be coming from the fan under the rubber skirt by the wiper blades.
    Is this the heater blower box? And is it easily replaced serviced? And if it needs replacing, is it expensive!? I'm quite happy to live with it as its just a little noisier but was concerned of other damage.
  2. Re: Blower fan noisy, any ideas? noise coming from engine bay?
    Mar 2008
    11 Post(s)
    Sounds like the same issue I had a few months back (I have got a thread somewhere on here)
    In my case, it did eventually seize to work on demand and would take sometimes up to 30 mins before it turned on. Same-ish noise in your case and same location and sure enough, it was the blower motor.
    Audi had quoted just under £300 for parts but was done under extended warranty.
    From what I know, the wipers have to come off from the bottom to access the blower motor but apparently it is not that difficult to replace the motor.
    I would do a scan too - I had an error relating to the blower motor too
  3. Re: Blower fan noisy, any ideas? noise coming from engine bay?
    Nov 2012
    Somerset UK
    Totally doable as a DIY job as have had to change one on another car in the same location.
    You just need a wiper puller (less than £5 of ebay) and remember to mark where your wipers sit currently (with some tape) before taking them off
    It may be worthwhile looking to see if there's one compatible for your car on ebay like this one:
    #15548 Audi A4 B7 2.0TDI Avant 2007 Heater Blower Fan Motor | eBay
    But as you've not said your model or year (and I can't be bothered to go through your previous posts to locate this) it's a little needle in haystack to know if it's the right one for you.
    Try putting your cars details in your signature (as I've done) to save people some time and offer the correct advice
  4. Re: Blower fan noisy, any ideas? noise coming from engine bay?
    Cheshire
    Quote Originally Posted by smickers View Post
    I had this issue and it was leaves in the blower case. Audi cleaned them out and has been ever since.
  5. Re: Blower fan noisy, any ideas? noise coming from engine bay?
    Feb 2012
    Quote Originally Posted by bennettp23 View Post
    Thanks for the reply guys. I'll add a signature today.
    My car is a 2008 2.0 TDI TDV LE Avant(I think!)
    I guess youd have to go through the same steps to remove leaves as you would changing it.
  1. Please Help Heating fan rumbling like bag of marbles(in engine bay)
    By unclespevie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-12-2012, 11:04 PM
  2. Noise from engine bay
    By Jak68 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-09-2010, 06:26 PM
  3. Please Help Noise from Engine Bay
    By paulbunyard in forum Touran - Sharan - Caravelle
    Last Post: 16-04-2010, 09:44 PM
  4. Noisy blower fan
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-12-2009, 09:49 AM
  5. Noisy blower fan
    By Jimchoc in forum Passat - Archive Topics
    Last Post: 29-08-2006, 06:33 PM
