Thread: Air con intermittent
Results 1 to 10 of 12
  1. Air con intermittent
    Dec 2009
    Manchester
    I seem to have had this problem on and off since new! Sometimes when I press the air con switch it comes on and sometimes it doesn't. Sometimes it comes on after say five minutes and sometimes it just doesn't come on.
    It usually comes on if I stop the car and turn the ignition off and on and occasionally when I just turn the switch on and off. I had the pressure switch replaced about two years ago which seemed to solve problem, but it's back again!
    Any ideas? I can't imagine it would be the pressure switch. VW want £95 to look at it and if the switch is faulty they will replace it.
  2. Re: Air con intermittent!!!
    Sep 2008
    SE London
    There's two systems: Climatronic (with two small windows for temps) or pictorial zone display on RNS510. And Climatic three knobs.
    Which do you have?
    What car?
    Year, Miles?
    What do you mean "it comes on and sometimes it doesn't."? Blower, coldness, when you're at rest or when your moving? Do both your fans come on when you switch aircon on?
  3. Re: Air con intermittent
    Dec 2009
    Manchester
    It's the climatic. The fan and vent work fine it's just the airs not cooled!
    It's a passat 2009 2.0 tdi 140 with about 70k on the clock. Just noticed today, that if I leave it on all the time and don't turn off when I stop the car it seems to work.
  4. Re: Air con intermittent
    Apr 2007
    France
    12 Post(s)
    Mine's never turned off, summer or winter (demists quicker with the aircon on in winter). It's reckoned it's best to leave it on anyway, saves the seals drying out.
    1996 Laguna 2.2D
    1977 MGB roadster
  5. Re: Air con intermittent
    Sep 2008
    SE London
    System appears working then. I havn't re-gassed my Climatronic since compressor seized up in '08 and had it changed under warranty. This is the first summer the cooling appears weaker
    Refrigerant is type R134a following european environmental laws. The full charge level is 600 grams by weight. An aerosol of R134a with pressure gauge is available from Halfords. They describe the gauge not the weight method to fill: Halfords | EZ Chill Auto Air Conditioning Recharge
    A filling video and photos of the filler location are at:
    Charge Port Locator - Interdynamics Europe
    Halfords own video is at:
    Kwik Fit auto centres will re-gas for you. If there’s no change in your system’s operation, they won’t charge. £49 as of May, 2014. MoT Testing &amp Servicing
    Last edited by RichardSEL; 02-07-2014 at 02:51 PM. Reason: location, location, location
  6. Re: Air con intermittent
    Dec 2009
    Manchester
    Seems to work if I leave it switched on all the time! I wonder if it's a faulty switch?
  7. Re: Air con intermittent
    Sep 2008
    SE London
    If you get cold effectively only when you've got forward motion say >30mph, or have had forward motion; and you get nothing when standing still from startup (after about five mins or so) then it's your G65 switch
    If you get no cooling even though you've got forward motion then it'll be your RCV valve on your compressor.
    There's no diagnostics on the Climatic system itself. Climatic can only be read in the HVAC section of a VCDS scan. But from what you describe I'd try the re-charge first to see whether that brings up your coldness. Then the G65 switch -- you won't loose refrigerant coz it sits on a Schraeder valve. Then lastly the RCV where you will have to evacuate your refrigerant to change out.
    I've got those three detailed in my Climatronic .doc, but you won't have the diagnostics part of it. PM me an e-mail address and I can attach it by reply
  8. Re: Air con intermittent
    Dec 2009
    Manchester
    Started playing up again even when switched on!! Any ideas?
  9. Re: Air con intermittent
    Dec 2009
    Manchester
    Seems weird now. Sometimes when I turn the air con on the air doesn't cool, but when I turn it off after a few minutes the air gets cooler, not cold but defiantly cooler!
    Just wondering if it could be a temp sensor fault?
  10. Re: Air con intermittent
    Sep 2008
    SE London
    What have you done so far?
    Could be a sensor. Find someone with VCDS and do a basic settings from the help .doc.
    Do an Autoscan too and post here? That could show up more listed under HVAC
    VWAF User Location Map - VCDS - Google Maps
  1. Please Help A3 2006 1.9TD air con intermittent problem
    By rider1000 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-06-2014, 09:54 AM
  2. Mr Suzanne Tomas & the Air con con
    By Wuffles in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-04-2014, 07:33 PM
  3. Important JCB VW Ashford Kent - DONT ALWAYS TRUST A MAIN DEALER - AIR CON... CON
    By 03sharanman in forum Touran - Sharan - Caravelle
    Last Post: 30-01-2014, 01:59 AM
  4. 2003 1.2 polo no air con, cant change vents air flow direction
    By clyde in forum Polo - Derby - Lupo - Fox
    Last Post: 21-09-2013, 08:31 PM
  5. Replies: 3
    Last Post: 21-07-2013, 12:59 PM
