Thread: problem with Audi A6
  1. problem with Audi A6
    Jun 2014
    Zimbabwe
    Hello
    I have an Audi A6 2.7L Year 2002, recently had damage underneath the car which resulted in engine oil and gear box oil leaking , I have since got these covers repaired and then replaced both engine oil and gear box oil. When I then tested the car there was no power when I tried to take off I have to rev it for about 20 seconds for it to start moving slowly .. Once in motion it drives somewhat normally but whenever I stop I have to go through the slow take off again.
    Also the dash board gear indicator is not responding when I change gears, all of them are lit up whichever gear I engage . I have taken it to diagnostic and the following errors have occurred
    1. 16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
    2. 17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    3. 16689/P0305/000773 - Cylinder 5 Misfire Detected
    4. 16690/P0306/000774 - Cylinder 6 Misfire Detected
    5. 16686/P0302/000770 - Cylinder 2 Misfire Detected
    6. 18010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low
    I have since done a minor service changing spark plugs and filters, but the problem is still there.
    Please can you assist me .
    Regards
    Jonathan Karonga
    +263 772233559
  2. Re: problem with Audi A6
    Apr 2009
    Epsom Downs
    Assuming it's a tiptronic gearbox, the symptoms sound like low oil level.
    As the oil has been changed lately, check the level using the (long-winded) Audi procedure to fix the problem or at least eliminate it as a possible cause.
    Does the engine rev-up quickly and cleanly when in neutral? if so, clear the fault codes and try again once you've checked the tiptronic oli level.
    If it's a manual box, I give up....
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  1. Please Help Audi a4 b6 a/c problem
    By jefrakos in forum Chat - Completely Off Topic
    Last Post: 06-07-2013, 06:51 PM
  2. My First Audi and problem!
    By Tsuyoi in forum New Member Introductions
    Last Post: 19-03-2012, 02:18 PM
  3. Audi A6 audi navigation plus dvd problem
    By Granta6 in forum Home Tech Shed
    Last Post: 05-09-2010, 04:30 PM
  4. Audi A4 Problem
    By Dave2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-01-2009, 03:27 PM
  5. Audi cd problem
    By Fatboyjarv in forum In Car Entertainment
    Last Post: 11-12-2008, 11:29 AM
