Thread: V6 that feels like an oil burner!
  1. Unhappy V6 that feels like an oil burner!
    Dear all,
    I have a A6 2.4 quattro 2002 100k with a rough idle for months now. I have changed the spark plugs, HT leads, Coil Pack, Engine Flush, Injector Flush, Fuel Filter and yes you guessed it no joy! There are no codes at all.
    Anyone got an idea what could be next? A garage said clean the throttle body. Will this work? I have looked and I cant get to it very well.
    Please give me some ideas!
  2. Re: V6 that feels like an oil burner!
    Sep 2007
    Plymouth
    A colleague was experiencing similar sypmtons with his 2.4. He tried a couple of dealers, who both couldn't diagnose the problem! I recommended my local garage....throttle body needed a good clean. I reckon it could be worth the effort in any event.
  3. Re: V6 that feels like an oil burner!
    Jun 2007
    Defo check the throttle body. my 2.8 v6 started like that 108k and got worse turned out was the valve train (exhause valve stem seals and followers) turned otu to be friking expensive. i hope the throttle body clean works for you. check oil useage and check for any top end vibrations.
  4. Re: V6 that feels like an oil burner!
    Jun 2007
    aylesbury, bucks
    ive got a 2.8 which goes like stink. hope you get it sorted as these little problems are the most annoying arnt they. you know its 90% certain to be something small and simple but you know its going to cost. good luck.
  5. Exclamation Re: V6 that feels like an oil burner!
    Sounds like the old throttle body clean. My car was until recently doing the same. Cleaned the throttle body ( without taking it off ), a bit awkward mind you. I managed it with some White spirit and cleaned the body and the butterfly until cloth was clean. Be careful with the butterfly 1) not to bend or scrape it 2) Do not let it snap back shut when releasing it after cleaning.
    If you have VAG Com then the fault should appear as :
    Fault : Throttle body fault in basic settings
    One other thing, check the throttle cable at closed position, if you can move it downwards and the throttle mechanism closes more to shut position, move the circlip on the adjuster up a notch or two, to release tension until idle is stable.
    Don't no why this happened, but cable was keeping throttle slightly open, screwing up the ECU resulting in poor idling.
    When I did this the car was able to perform a throttle body adjustment without any problems whatsoever, idle was spot on afterwards.
  1. Got an oil burner on my hands.
    By Oddball in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-06-2007, 08:09 PM
