Thread: Engine Fault Warning Light - 1.6TDi
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
  1. Re: Engine Fault Warning Light - 1.6TDi
    #21
    Feb 2011
    Herts, UK
    Would the fault code generated on Rabid's VCDS be the same as those generated on the diagnostic equipment a VW dealer would use?
    2010 Golf Plus 1.6TDi SE Bluemotion
  2. Re: Engine Fault Warning Light - 1.6TDi
    #22
    Sep 2008
    mostly in the garage
    The danger with using the dealer is they'll not only rob you for a diagnostic they may just condemn the controller as a best guess.
    Reference the "No ASAM data"....... A normal scan appears like this one.....
    Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 ML HW: 03L 907 425 C
    Component: 1,6l R4 CR td H43 9052
    Revision: --H43--- Serial number: 00000000000000
    Coding: 08114014032500080000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM16TDI02103L906023ML 003005
    ROD: EV_ECM16TDI02103L906023ML_VW36.rod
    VCID: 7CF3B99AF71A8DF87DD
    No fault code found.
    Readiness: 0000 0000
    .....note the line beginning with "ROD:" which is missing from yours.
    The lack of entries of time, date and mileage normally happens with a 'no comms' error.
    Who knows it could be a faulty controller, I would e-mail RossTech with a copy of the scan or post on their forum.
    Ross-Tech Forums
  3. Re: Engine Fault Warning Light - 1.6TDi
    #23
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: Engine Fault Warning Light - 1.6TDi
    #24
    Jun 2014
    Quote Originally Posted by Bob_S View Post
    Yes, every scan I have run previous has generated fault codes that the vw dealership recognised and confirmed the faults, I have never had a code like yours come up before, it is not the normal format of code.
  5. Re: Engine Fault Warning Light - 1.6TDi
    #25
    Sep 2008
    Quote Originally Posted by Keithuk View Post
    ROD still isn't an error code.
    We all agree on that but it's still odd that the data isn't available for a 2010 controller and something to do with that controller is putting the mil on.
    Is the vcds software up to date?
  6. Re: Engine Fault Warning Light - 1.6TDi
    #26
    Feb 2011
    Herts, UK
    I have signed up to the Ross tech forum but I can't post in the relevant forum because I do not have a VCDS. If anyone here is registered would they be so kind as to post up a copy of my scan? I can e-mail it if required. Otherwise it is looking like I will have to pay the VAG dealer rates just for them to diagnose it.
  7. Re: Engine Fault Warning Light - 1.6TDi
    #27
    Feb 2011
    Herts, UK
    So much for the Ross Tech Forum! I managed to post the scan on there only to be told they won't help me because the scan came from pirated software!!!
  8. Re: Engine Fault Warning Light - 1.6TDi
    #28
    Sep 2008
    Only to be expected.
    Perhaps do another scan with genuine software, maybe would reveal more or different details
    Sent from my GT-S5830i using Tapatalk 2
  9. Re: Engine Fault Warning Light - 1.6TDi
    #29
    Feb 2011
    Herts, UK
  10. Re: Engine Fault Warning Light - 1.6TDi
    #30
    Sep 2008
    Their issue is the pirated software not the device used.
    The software version in your scan is out of date. If it is genuine software, when it's connected it would automatically notify the user of the need to update.
    A scan with genuine software may quite possibly give a more usual informed result. Any one here near you? VWAF User Location Map - VCDS - Google Maps
  1. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2014, 10:02 PM
  2. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  3. intermittent turbo fault, engine warning light.
    By Leigh1972 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2012, 07:48 PM
  4. Please Help Passat 1.8T Engine/Fuel/Ignition Fault - Catalyst Warning light on dash illuminated
    By Captain Babble in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 05:33 PM
  5. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
