Right. Had an issue with airbag light on dash and have posted previously. Believe I have solved down to dodgy connectors under the seat. If I push connectors together firmly and make sure seated properly and clear codes using vcds they go but as soon as seat is moved they come back. Bascially im not paying vw a small fortune to fix and dont want to set airbags off.
Plan is to bin the connectors and hard fix via solder or crimped connections. few queries and want to check methodology.
Plan is to disconnect battery leave for 30 odd mins. Disconnect earth strap under seat (wherever it is, help needed here) cut off connectors then hardwire. Reconnect earth strap then reconnect battery and clear faults.
Should I solder. Someone said vw dont recommend thia. Or should I use crimp connectors.
Anything I should be aware with battery or procedure.
Does any of the above sound like an issue.
Help would be much appreciated.
