Thread: 1996 A4 TDI SE
  1. 1996 A4 TDI SE
    Jul 2006
    I have problem with my A4.
    When I bought it the car developed a problem when I was up at speed the car would lose a bit of power etc...
    It was as if the brakes were coming on a bit and slowing the car down.
    I checked the brakes and the offside rear pads were worn down to nothing.
    I took it to a mate of mine who told me I needed a caliper.
    i had a look at the old caliper and it was totally humped.
    I got a caliper and new pads etc.
    After this the car was going a lot better.
    It was due a service and a timing belt. I got both of these done. I also changed the tensioners etc...
    Now there seems to be a lot of black smoke coming from the engine at low revs and sometimes when in 5th gear and cruising at 60-70mph.
    I have also had a loss of power when at 60-70mph when going uphill.
    It is as if the turbo is not kicking in.
    Anyone else had these problems or does anyone know anything about them ?
    Any help would be appreciated.
    Jan 2006
    Check to see if your car is a fly by wire set up (no throttle cable ) if so then there is a good chance that the pump timing is out ,if this is not the case the third fuel injector has a electric plug on it ,either the plug is undone,faulty or the injector is faulty , this injector is the control injector for the others and it might be sending incorrect signals to the brain causing overfueling this gives the symptoms that you have...Good luck
  1. A4 1.8t 1996 P reg idling problem
    By mikeyg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2007, 06:11 PM
  2. No accelerator 1996 tdi
    By teddydog in forum Passat - Archive Topics
    Last Post: 09-02-2007, 08:02 PM
  3. a4 1996 2.6 se air con fault?
    By pintpotter in forum Chat - Completely Off Topic
    Last Post: 21-01-2007, 10:20 PM
  4. Mk3 Golf GTi 16v 1996 (P)
    By jlx45v in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-11-2006, 10:16 PM
  5. 1996 a6 2.6
    By dolly80 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 05-09-2006, 06:41 PM
