Thread: Central locking remote.
Results 1 to 8 of 8
  1. Central locking remote.
    Dec 2006
    Maidstone, Kent.
    On my 2003 Passat if I press the unlock button on the remote it will unlock the drivers door only, which I find a tad annoying, is it possible to alter this so that the initial press will open all doors, rather than having to press the button twice?
    Thanks in advance.
  2. Re: Central locking remote.
    Feb 2007
    as i understand it, you need vag-com or someone with it, to access the computer to enable the function.
    see if there is someone with vag-com near to you who will do it for a small fee.
    or try the ********.
    Fozzie!
  3. Re: Central locking remote.
    A, A
    I prefer it on mine, but as above someone with a VAG COM local will help you out.
    Just another B7 Estate
  4. Re: Central locking remote.
    Ive posted this elsewhere!
    Get the battery voltage checked. Poor car batteries can give central locking problems.
    I could only open the passenger door with the key fob on my passat.
    When the battery I knew was on its last legs was changed the central locking worked normally again.
    One press opened the drivers door two presses opened the other doors.
    MrG
  5. Re: Central locking remote.
    Quote Originally Posted by Dave Elcome View Post
    Thanks in advance.
    Get a cheap Vag Com lead off ebay and download the softwear, if you have a Passat you will need it!!
  6. Re: Central locking remote.
    Jul 2007
    Wicklow, Ireland
    With all due respect to everybody, telling somebody to go get VAG-COM isnt answering his question......If he gets VAG-COM, which settings does he have to change to get all doors (and possibly the boot) opening with one click of the keyfob?
    TIA
    DR
  7. Re: Central locking remote.
    Jul 2008
    Blackburn
    Hi guys, I've just got a Passat (T reg) 1.8 SE 20v.
    Is it correct that I should press the remote central locking once, to lock car, activate deadlocks and activate alarm ?
    It's a bit different to other cars I've had, where you have to press remote twice to activate central locking, and alarms.
    Thanks.
  8. Re: Central locking remote.
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by frank-59 View Post
    Thanks.
    Yes, however it does vary between model years.
    I've had 2 B5s, the 1st a '98 one was one press to lock, deadlocks and alarm, 2nd press removed deadlocks and alarm, signified by led on drivers door not flashing.
    the other a 2000 one, doesn't seem to do this with the 2nd press.
    Nothing to see here, move along..
  1. Remote central locking problems
    By yogise in forum Passat - Archive Topics
    Last Post: 18-10-2007, 03:54 PM
  2. Remote Central Locking
    By the_italian_job in forum Chat - Completely Off Topic
    Last Post: 30-06-2007, 05:25 PM
  3. Remote central locking problem
    By ImolaOrange in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 03:05 PM
  4. Help with remote central locking please
    By sf01 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-02-2007, 12:35 AM
  5. Remote central locking
    By dazza in forum Passat - Archive Topics
    Last Post: 31-12-2006, 04:11 PM
