Thread: superb 03 1.9tdi screeching noise when.on full lock plus climatronic not cooling
  1. superb 03 1.9tdi screeching noise when.on full lock plus climatronic not cooling
    Aug 2008
    When on full lock either way get screeching off drive belt. Plus climatronic display shows -- where temp should be and isn't cooling. Is it just time for registering or bigger problem? I
  2. Re: superb 03 1.9tdi screeching noise when.on full lock plus climatronic not cooling
    Aug 2008
    Quote Originally Posted by thekopite View Post
    it should say time for regas bloody predictive text
  3. Re: superb 03 1.9tdi screeching noise when.on full lock plus climatronic not cooling
    7 Post(s)
    The screech could be;
    Worn aux belt tensioner
    Worn aux belt
    Dodgy alternator pulley (do a search on here, lots of info)
    Knackered steering rack, pressure release valves in the rack (unlikely though)
    Aircon, as you have said, get it regassed and report back if no different.
  4. Re: superb 03 1.9tdi screeching noise when.on full lock plus climatronic not cooling
    Aug 2008
    Quote Originally Posted by BigCol View Post
    Worn aux belt
    Had belt and tensioner replaced when alternator tensioner snapped off last year it's only when on full lock no other time
  5. Re: superb 03 1.9tdi screeching noise when.on full lock plus climatronic not cooling
    7 Post(s)
    Probably alternator pulley then starting to go.
    Is you PAS fluid topped up and the correct type?
  6. Re: superb 03 1.9tdi screeching noise when.on full lock plus climatronic not cooling
    Dec 2007
    8 Post(s)
    The older 1.9 tdi had a crank pulley that had a cushion of rubber that the steel ribbed pulley sat on,in this case it was driving the altenator only,the p.s. had a seperate
    v belt. Sometimes the pulley could skid on this cushion causing squeal when high demand from was required. It might be worth a look to see if your model has
    this type of pulley fitted. By marking the pulley and cushion you will see if the marks move.
  7. Re: superb 03 1.9tdi screeching noise when.on full lock plus climatronic not cooling
    7 Post(s)
    If it is an 03 then 99% it has an PD (probably an AWX) engine which has the everything driven by one aux belt except the aircon compressor.
  1. Knocking Noise on full lock
    By tajgill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-04-2016, 09:05 PM
  2. Rumbling noise on full lock
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-07-2010, 03:45 PM
  3. Knocking noise on near-full lock...
    By Ap3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2009, 10:48 AM
  4. Clicking noise on full lock?
    By bushid0 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-05-2008, 12:18 AM
  5. Noise on full lock
    By Spiceman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-04-2008, 03:03 PM
