Thread: AAAAAAARRRRRGGGGGHHHHH!! help! - or if I were feeling helpful with my titles - My Golf creaks
  1. AAAAAAARRRRRGGGGGHHHHH!! help! - or if I were feeling helpful with my titles - My Golf creaks
    Sep 2007
    i have notice my car has a creaking noise seems to be when setting off in 1st or 2nd n also noticed it again when pulled car over small lump at top of drive,i was wonderin shocker top bushes or drop links,had bottom arms fitted 2weeks ago so not them,also creaking when bounce frt end of car but car settles well so doesnt seem like the shockers
    any ideas would be appreciated
    also a rattling had a rattling seems to be from under dash area at about 1n half grand when you hold accelerator there n also hear it when shut drivers door(its not the door though for def) cant be heard from outside,wonderin if something to do with bonnet cable or something elso coming through bulkhead
    NOT ONE OF YOU HAS GOT AN OUNCE OF STYLE IN YA!!
    Golf gttdi 150arl,giac software,full milltek non-res system,anni lamps now gone for A3 2.0tfsi quattro s-line giac mapped 260bhp,S3 diffuser,lcr splitter
  2. Re: AAAAAAARRRRRGGGGGHHHHH!! help!
    Sep 2007
    Leeds
    I had the same on my Bora, check the springs, might be rusty or even snapped! Does it still make the niose when you take it out in the rain? I sprayed mine with WD40 and has stopped creaking noise for now.
    Steve
  3. Re: AAAAAAARRRRRGGGGGHHHHH!! help!
    A, A
    Could be 3 things here. Very common faults all of them and i have had them all.
    1. Anti roll bar bushes have worn, so it creaks as you go over bumps.
    Try opening the bonnet, grabbing the front of your car and pull the car up and push it down, this duplicates the noise. Going over speed bumps makes the biggest noise.
    2. Centre exhust mount has broken. Go to Kwik Fit and have it welded, had mine done £15.
    Noise Appears at low revs on mine.
    3. Radiator mounts have broken, this was most noticable on closing the door or boot, But more like a squeeky sound.
    You can check this by, grabbing the radiator and shaking it, see if you can duplicate the noise.
    Bet you its one of them, nothing major.
    Just another B7 Estate
  1. strange engine seizure feeling
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-10-2007, 11:04 PM
  2. How easy or difficult to...change a steering wheel (full descriptive titles help!)
    By A6_JAck in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 14-09-2007, 11:35 AM
  3. thread titles / headings
    Last Post: 26-06-2007, 11:48 PM
