Thread: Correct name
  1. Correct name
    Dec 2010
    Chester Cheshire
    Who can tell me the correct name for the two valves in the plenum chamber for the aircon that are known to have manufacturing swarf stuck in them.
    Searched in vein
  2. Re: Correct name
    Sep 2008
    mostly in the garage
    It seems to be known as simply a pump/valve unit. Audi would be able to identify it by it's actuator numbers..N175, N176 and V50.
    (The pump/valve unit comprises the coolant recirculation pump -V50 and the left/right heat regulation valves (-N175/-N176).
    The heat regulation valve, left -N175 regulates the coolant flow fed to the associated heat exchanger for the right side of the passenger compartment from the engine cooling circuit.The valve is operated by the Climatronic control unit -J255 by a pulse width modulated voltage signal.)
  3. Re: Correct name
    Dec 2010
    Chester Cheshire
    Thanks c4a5er, seems to be a known fault with them
  4. Re: Correct name
    Apr 2012
    Aylesbury, Bucks
    Read the pdf doc that's near the top of the search - can be swarf, can be other things.
    Google
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  5. Re: Correct name
    Dec 2010
    Chester Cheshire
    Looks like I need to get my outside air temp sensor sorted first before I go any futher
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 G
    Component: KLIMABETAETIGUNGH05 0160
    Revision: 00000028 Serial number: 00000000191365
    Coding: 0001044
    Shop #: WSC 02325 785 00200
    VCID: DBB15A061AD4EAC62E5-808E
    1 Fault Found:
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 L
    Component: KOMBIINSTR. M73 H11 0660
    Revision: 00100000 Serial number: 4RA71HHA5
    Coding: 2308443
    Shop #: WSC 01214 210 01214
    VCID: 1E379312C9463FEE89B-804B
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 41
    Mileage: 322169 km
    Time Indication: 0
    Date: 2014.04.17
    Time: 08:00:25
    00256 - A/C Pressure/Temperature Sensor (G395)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 89
    Mileage: 322169 km
    Time Indication: 0
    Date: 2014.04.16
    Time: 16:29:21
  1. Correct turbocharger
    By TOnyt-5 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-08-2011, 10:41 PM
  2. Question Correct coolant, and where to get it from?
    By wj209980 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-07-2011, 06:42 PM
  3. Please, is this the correct oil for my A6?
    By crx16 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-03-2011, 07:00 PM
  4. Correct Oil
    By kasbridge in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-04-2008, 04:24 PM
  5. Correct antifreeze
    By lufftube in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2008, 04:20 PM
