Thread: B8 concert audio - which pre-amp source?
  1. B8 concert audio - which pre-amp source?
    Feb 2014
    Leicestershire
    19 Post(s)
    Guys,
    Sure someone has tapped into the pre-amp sources with the concert radio and fed it to an aftermarket amp?
    I have tried the rear source and it seems to be clipped below 100hz.
    I want a source that is full range so I can LPF it at my amp and supply my sub.
    Any point trying the front?
    I am using the 'sub' out single channel and a line level converter but it seems to roll off at above 90hz and this cuts all the punch from the new sub, plus I don't like the level converter thing, always worried the in signal is too high a voltage and it's not that clean a signal.
  2. Re: B8 concert audio - which pre-amp source?
    Feb 2014
    Leicestershire
    19 Post(s)
    No one?
    The sub connection has some serious flaws...
    First it is not muted when the parrot makes/receives a call!
    Second it is very limited in range, it rolls off below 35Hz and above 90Hz.
    The new sub is very impressive but can deal with much more range than the didy thing next to the spare tyre.
  1. external audio source
    By lazzlo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-03-2014, 07:37 AM
  2. Question Audio From SatNav Through Concert 2
    By A4 Lad in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-03-2013, 11:50 AM
  3. Question SatNav Audio Through Concert Stereo Help
    By A4 Lad in forum In Car Entertainment
    Last Post: 03-03-2013, 12:42 AM
  4. Question Concert audio and amplifier
    By didkobandita in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-03-2012, 08:47 AM
  5. Question Concert radio, standard audio setup & installing a new unit
    By fuse in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-08-2009, 11:33 PM
