Thread: Dodgy Fuel Gauge
  1. Dodgy Fuel Gauge
    May 2014
    England
    My fuel gauge will just randomly stop moving (usually just above 1/2 and just above 1/4). I filled it up last night from just above 1/4 and it went to just under 1/2 and then when I came to use it this morning was up at 3/4.
    I've pulled fuses 15 and 28 and started the ignition and then turned off and replaced and it fixes the problem but then it comes back again pretty quickly. What do I need to fiddle with or replace?
    Audi A4 Avant Sport 2.0L FSI in Ebony Black
  2. Re: Dodgy Fuel Gauge
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I dont know if this will work on this vehicle, but, it was possible to earth out the feed to the tank sender and the needle would deflect to either 1/1 or zero. This generally proved the gauge to be working okay. You would need to cycle the ignition each time you check. If okay tnen most likely sender issue.
    Alan.
    VW T6 150 DSG Camper £££
  1. Engine light on & dodgy coolant temp gauge
    By Celica-Boy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-01-2011, 10:55 AM
  2. Dodgy Temp Gauge
    By Thias in forum Polo - Derby - Lupo - Fox
    Last Post: 10-08-2009, 05:29 PM
  3. Another (other) fuel gauge problem. (And volt gauge.)
    By M3 Compact in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-08-2009, 10:23 AM
  4. Golf 1.4 will not idle - dodgy fuel!
    By berko in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2008, 03:27 PM
  5. temp gauge and fuel compsumption gauge
    By mikeA4_88 in forum Archive posts
    Last Post: 03-02-2008, 11:23 PM
