Thread: Upgrade 2008 3.2 TT to TTS LED DRL Adaptive Headlights, Problem
  1. Upgrade 2008 3.2 TT to TTS LED DRL Adaptive Headlights, Problem
    Jun 2014
    Boston USA
    I up graded my 2008 audi tt3.2 roadster,
    drl
    TO:
    tts LED drl adaptive lights.
    I seem to have lost the adaptive feature.
    Now:
    - lights mostly work,
    drl, turn signals, headlights, high beams ALL OK
    - no adaptive function on headlights
    - dashboard warning: dynamic headlight range control defective
    - (vagcom finds) (55)xenon range, fault 02071, no signal communication
    I coded as per audi (german) tech bulletin.
    Any Ideas?
    Is there a wire loom change needed?
    (was told it was plug, recode, and play)
    Thanks if you can help,
    Tony Vezza
    Boston USA
  2. Re: Upgrade 2008 3.2 TT to TTS LED DRL Adaptive Headlights, Problem
    Jun 2014
    Boston USA
    Here's more information about my headlight problem.
    Again the light mostly work EXCEPT for afs (adaption).
    When I try to code (55)Xenon Range I get:
    coding rejected error 22:conditions not correct or request sequence error
    This is using a correct (non zero wcs) and password. It's
    already coded from before to the correct value (25).
    But it is curious that I can't change it.
    Here is the vcds log of (55)Xenon Range.
    It shows NOSUBSYSTEM for the afs units!
    The headlight assemblies are supposed to be AFS: 8J0 941 003/004 AJ
    I opened one and it has the afs motor in it.
    I'm suspecting a wiring problem?
    Could the adaption cause this?
    I had Xenon AFS before the upgrade and I'm using the same
    underdash controller.
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000025
    Shop #: WSC 01236 785 00200
    VCID: 29527000807A5056EC9-807C
    Subsystem 1 - Part No: NOSUBSYSTEM
    Component: AFS-Modul links
    Subsystem 2 - Part No: NOSUBSYSTEM
    Component: AFS-Modul rechts
    1 Fault Found:
    02071 - Local Databus
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 97960 km
    Time Indication: 0
    Date: 2014.06.10
    Time: 00:02:58
    Full vcds log:
    Tuesday,10,June,2014,12:05:26:33650
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    Workshop Code: 001 02778 000001
    VIN: TRURD38J081003132 License Plate:
    Mileage: 97950km-60863mi Repair Order:
    Chassis Type: 8J (1K0)
    Scan: 01 03 08 09 0F 14 15 16 17 19 22 25 26 37 42 44 46 47 52 55
    56 65 77
    VIN: TRURD38J081003132 Mileage: 97950km/60863miles
    01-Engine -- Status: OK 0000
    0F-Digital Radio -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    22-AWD -- Status: OK 0000
    26-Auto Roof -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 022-906-032-BDB.lbl
    Part No SW: 022 906 032 HF HW: 022 906 032 GP
    Component: TT-3.2-HS-LEV2 G 0863
    Revision: 1QH02--- Serial number: AUX7Z0G3FNF00E
    Coding: 0000172
    VCID: 56A80BFCE1842FAE91B-8003
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8J0-614-517.clb
    Part No SW: 8J0 614 517 HW: 8J0 614 517
    Component: ESP MK60E1 0130
    Revision: 00H52001
    Coding: 0026193
    VCID: EAD0CF0CC5FC1B4EA53-80BF
    Address 08: Auto HVAC Labels: None
    Part No SW: 8J0 820 043 AA HW: 8J0 820 043 AA
    Component: J255 Klima 1 Zone 0060
    Revision: 00H07003 Serial number: 00000001028843
    Coding: 1048870
    VCID: 65CA3C30ACE2B436081-8030
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 H HW: 8P0 907 279 H
    Component: Bordnetz-SG H46 1802
    Revision: 00H46000 Serial number: 00000006959499
    Coding: F1041A83C0141C000318000018000000002800005D260802
    VCID: 4280C7AC1D0CA30ECD3-8017
    Subsystem 1 - Part No: 8J1 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer AU354 H07 0060
    Coding: 00064784
    Shop #: WSC 01236
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00149804
    Shop #: WSC 01236
    Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
    Part No SW: 8E0 035 593 N HW: 8E0 035 593 N
    Component: SDAR SIRIUS H08 0150
    Revision: 00000000 Serial number: AUZ4Z7G0226265
    Coding: 0000000
    Shop #: WSC 00000 000 00000
    VCID: 346C917457B81DBE4FF-8061
    Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
    Part No SW: 8J0 910 376 HW: 8J0 907 376 A
    Component: J250 Raddaempfung 0050
    Revision: --H16--- Serial number: 190DPH 7053492
    Coding: 0000014
    VCID: ECDCC914CF08057ED7F-80B9
    Address 15: Airbags Labels: 8J0-959-655.lbl
    Part No SW: 8J0 959 655 HW: 8J0 959 655
    Component: -F Airbag 9.43 H02 0020
    Revision: 93H02002 Serial number: 0036K00168NO
    Coding: 0011590
    VCID: F9F2E040B05AA0D65C9-80AC
    Subsystem 1 - Part No: 8J0 910 339 A
    Component: BF-Gewichtsens. H02 0030
    Subsystem 2 - Serial number: 00HGV
    Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
    Subsystem 4 - Serial number: 000000ÿ†6332DRB4052C4D99.ÿ†63
    Subsystem 5 - Serial number: C4D99.ÿ†6342DRB4051DD32CXÿ†63
    Subsystem 6 - Serial number: DD32CXÿ†63747RB4023396FBWÿ†63
    Subsystem 7 - Serial number: 396FBWÿ†63847RB402338F15Lÿ
    Subsystem 8 - Serial number: 38F15Lÿ
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004041
    VCID: 4182C8A0180AB816D49-8014
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments Labels: 8J0-920-xxx-17-MY7.lbl
    Part No SW: 8J0 920 990 C HW: 8J0 920 990 C
    Component: KOMBIINSTR. VDO H21 0070
    Revision: D0H21004 Serial number: 2243G004003377
    Coding: 0117268
    Shop #: WSC 01308 067 57207
    VCID: 3260976CADAC138E5D3-8067
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 33001074130646
    Coding: FD8F23EA27005100
    Shop #: WSC 02778 001 00001
    VCID: 2F669E18BE9E3E6632D-807A
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 L
    Component: Haldex 4Motion 0116
    Coding: 0000001
    VCID: 3668AB7C41C40FAE71B-8063
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H21004 Serial number: AUX7Z0G3FNF00E
    Address 26: Auto Roof Labels: 8J7-959-255.lbl
    Part No: 8J7 959 255 B
    Component: 256 VSG TT H13 0110
    VCID: 3E78B35C69F4C7EEA9B-806B
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8J0 035 192 B HW: 8J0 035 192 B
    Component: RNS-E US H10 0260
    Revision: 01S Serial number: AUZBZ7G3800957
    Coding: 0610637
    Shop #: WSC 01126 444 83883
    VCID: 285475049B70695EF37-807D
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
    Part No: 8J7 959 801 C
    Component: Tuer-SG H02 0060
    Coding: 0001077
    VCID: 3C7CB9547FE8D5FE87F-8069
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 8J1 909 143 B
    Component: EPS_ZFLS Kl.155 H07 1807
    Address 46: Central Conv. Labels: 8J0-959-433.lbl
    Part No: 8J0 959 433 A
    Component: KSG H08 0070
    Coding: 9B90328241382D090F0FC88A0473
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 47: Sound System Labels: 8J0-035-223.lbl
    Part No SW: 8J0 035 223 B HW: 8J0 035 223 B
    Component: J525 Amp Std H03 0120
    Revision: 00H03001 Serial number: 93802001937806
    Coding: 0106136
    VCID: 234E6228E2568A06A65-8076
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
    Part No: 8J7 959 802 C
    Coding: 0001077
    VCID: 3D7AB45064F2DCF6B01-8068
    Coding: 0000025
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 97960 km
    Time Indication: 0
    Date: 2014.06.10
    Time: 00:02:58
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0610637
    Address 65: Tire Pressure Labels: 8J0-907-273.lbl
    Part No SW: 8J0 907 273 A HW: 8J0 907 273 A
    Component: J502_RDK H02 0300
    Revision: --H02-D0 Serial number: 12679671933950
    Coding: 0840019
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 A HW: 8P1 862 335
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005597099
    Coding: 0011422
    VCID: 356AAC705CC204B6781-8060
    End
    Tony Vezza
    Boston USA
  1. installed and activated TTS LED DRL's to my mates 2008 (8J) TT
    By burnsy_b in forum VCDS - General Questions
    Last Post: 07-06-2014, 10:25 PM
  2. Cost of upgrading bi-xenon and LED DRL headlights
    By kinlongso in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-11-2012, 05:11 PM
  3. Adaptive Xenon Headlamps and LED DRL
    By Furion in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-05-2012, 06:45 PM
  4. New led headlights - problem - please help
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-05-2009, 09:42 PM
  5. adaptive headlights
    By tlionhart in forum Chat - Anything with wheels
    Last Post: 17-12-2008, 10:39 PM
