Thread: P2563 error code, flashing coil light, flashing EML (engine) light
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 61
  1. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #21
    What is the engines type code? From the description it sounds like a CE?? series with the electronic turbo actuator, the diaphragms on these split. There is no alternative to taking off the turbo and having a new actuator fitted, IF you can find someone who can/will do this or if they can even get hold of an actuator. Remove the vacuum pipe to the N75 valve and suck on the pipe, i.e. the actuator it is connected to, can you draw air or is there a vacuum resistance?
    So, I've sucked on the hose and there appears to be vacuum resistance. I can see the piston move as my face goes red.
    In any case, if this is the problem, any ideas where I can find a garage in Europe which will know what to do. I suspect even if I brought in a new actuator and asked a random garage to fit it, I would get a blank stare.
    I guess I could always take it to VW and get a whole new turbo, but that is the absolute last resort...
    Here are a couple of photos of the hose connecting the actuator and the valve. There are no hose clamps on this, so I am not sure if this could be the issue?
    Cheers!
  2. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #22
    134 Post(s)
    2004 Post(s)
    A CEBB engine then..... You need to check the turbo actuator diaphragm to see if it is leaking.
  3. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #23
    OK, thank you. I am trying to find someone capable around where we are in Italy, but this is proving somewhat difficult.
    I also forgot to mention that the brake vacuum pump is making a tapping noise on occasion (see related):
    Unusual tapping noise
    Could this be at all related to my turbo issue?
  4. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #24
    134 Post(s)
    2004 Post(s)
    Yes, the system is vacuum controlled and totally dependant on a good vacuum throughout the system, one leak anywhere can shut three systems down.
  5. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #25
    Norfolk
    Address 91: LT3 Engine Labels: Redir Fail!
    Control Module Part Number: 076 906 022 N HW: 076 906 022 G
    Component and/or Version: R5 2,5L EDC A020SG 7731
    Software Coding: 0003032
    Work Shop Code: WSC 00117 555 00000
    VCID: 1E33E8DDC9E8DEB2B2-804B
    1 Fault Found:
    009571 - Turbocharger Boost Control Position Sensor Circuit
    P2563 - 000 - Implausible Signal - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100000
    Fault Priority: 2
    Fault Frequency: 23
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 735 /min
    Speed: 0.0 km/h
    Voltage: 13.83 V
    Temperature: 162.0°C
    Lambda: -15.0 %
    Bin. Bits: 00001110
    Voltage: 1.520 V
    This code probably has nothing to do with vacuum or turbo as such. It is a code that is not used on your vehicle as you do not have a position sensor. I suspect the designers are trying to tell you that the Atmospheric pressure and map sensors do not agree with each other. If this code appears on switch on but no other problems occur, I would ignore it for now. It only needs fixing if it is causing limp mode.
  6. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #26
    Oh, very interesting... Would it make a difference I am driving 1-2km high up in the mountains?
  7. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #27
    134 Post(s)
    2004 Post(s)
    Quote Originally Posted by martin1810 View Post
    The CEBB engine uses a Mitsubishi Heavy Industries 49T77-07460 or 49T77-07535 which according to ETKA does not have a position sensor for the charge pressure positioner, a G581, BUT the wiring diagram on ELSA page 17 current tracks 215>217 clearly shows one, the pictures posted of the turbo show it has the composite bodied positioner and in the ELSA instructions for removing the turbo it states “pull off vacuum hose and connector from turbocharger”, a proper picture of the actuator would solve the problem. Chanick, can you PM me your UK reg number?
  8. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #28
    Thanks Crasher, PM sent.
    FWITW, the actuator on my van looks exactly like the one in the images above.
  9. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #29
    134 Post(s)
    2004 Post(s)
    Yes it is a CEBB engine as your ECU number indicated BUT it is a 2011, not a 2010 but ETKA FI suggestion infers that it has the non VNT turbo 076 145 702 C which is obviously wrong. The 076 145 702 C is the same as the later D and Q which is the one in the picture. The actuator can be replaced but it has to be set up on the bench, you need a turbo rebuild specialists help. http://www.be-turbo.com list the actuator under their part number 206208
  10. Re: P2563 error code, flashing coil light, flashing EML (engine) light
    #30
    Norfolk
    It seems I was wrong. I believe your vehicle uses an edc17cp20 ECU. If this is the case, it can produce this error code because of a possible Nox error (exhaust gas fault). My best guess is that the lambda regulation check is looking for a turbo actuator position so that it can calculated expected oxygen levels to determine lean or rich mixture. So when you switch on ignition the lambda check is failing because the actuator positioner is either not working or giving an out of range signal. Basically the ecu is trying to predict fuel air/ratio using turbo boost level. If the actuator does not give a position, the ecu cannot do its calculation. As long as this does not cause limp mode, I would ignore it. It should be ok to ignore the fault because when the engine is running the ecu can use other methods to calculate (probably turbo pressure) which do not rely on the actuator position.
  1. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2014, 10:02 PM
  2. Please Help Passat 2008 2.0CR TDI EML and flashing glow plug light
    By jasonmking in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-04-2013, 07:10 PM
  3. Flashing Coil Light
    By Shost in forum Polo - Derby - Lupo - Fox
    Last Post: 19-09-2009, 08:16 PM
  4. flashing coil light
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-08-2008, 04:00 PM
  5. Engine management & flashing coil light
    By JohnWithAGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 18-04-2008, 09:03 PM
