Thread: Water Pump Failure / Cam belts failure
Hybrid View
  1. Water Pump Failure / Cam belts failure
    Nov 2010
    Grimsby
    Seems my water pump has failed on 2.5TDi Allroad. Most of the belt has shredded and the car stopped. All the water is gone. My concern is timing belts going normally cause major damage.
    Is this the case on 2.5 V6 Tdi. A mate of mine had the same issue but is was only rocker arm damage.
    Any experiences of said timing belts going ?
    Fly
    gutted
    sad
    and probably skint
  2. Re: Water Pump Failure / Cam belts failure
    Oct 2011
    uk/germany
    The rocker arms are intentionally made weak so if you are lucky they will smash before the valves bend. If not you might as well find a 2nd hand engine...
  3. Re: Water Pump Failure / Cam belts failure
    Sep 2013
    My water pump went at 119000 miles on my 2.5 Tdi Avant.
    Got it home and at first the garage told me that they thought I had got away with a new belt, pump etc.
    On picking it up I heard a tappity tap sound, didn't sound too much and could only be heard at 2000rpm plus.
    The 'Brain Surgeons" at the garage said it was probably a stuck 'something' (I can't remember now) and I should give it a burn on the local D/C.
    For some reason, probably common sense I didn't and , over the next two weeks as the sound appeared at a reducing rev range I knew something was wriong.
    Took it back and the garage hadn't checked the cams and one of them had lost it's hardening.
    This resulted in another large bill and no apology for their lack of professionalism.
    Got away without any damage to valves though and the car is still with me at 162000 and it seems to be getting better with age if that's possible.
    When the belt is due, next time (at 200000 miles) I will treat it to a new pump, just to be safe.
    PS That garage is not visited any more.
  1. water pump failure
    By Achilleas in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-08-2014, 11:42 AM
  2. 03 A6 Allroad 2.5 tdi Water pump failure
    By big1pie2003 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-04-2012, 11:30 PM
  3. Please Help Water Pump Failure
    By connaco in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-02-2011, 06:32 PM
  4. Water pump failure
    By mickel2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-08-2009, 09:23 PM
  5. Water pump, symptoms of failure?
    By Redbrick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-12-2008, 02:26 PM
