Thread: Cruise control retrofit wire to ecu?
  1. Cruise control retrofit wire to ecu?
    May 2013
    England
    I have got all my parts needed to fit the mfsw with paddles and cruise control. I have one question before I start, I have seen a few people mention the need to run a wire to the ecu for cruise? Yet on others it hasn't been mentioned. Is this needed or only on certain models etc?
  2. Re: Cruise control retrofit wire to ecu?
    warp_speed Guest
    Never heard of it, normally all you have to do is programme the ECU that you have cruise fitted. This depends on the engine, but its easily done using the VCDS and change one of the Bit values in the ECU. Think all the communications between ECU and steering wheel module is done over the CAN connection, no dedicated Cruise wire. Perhaps they mean the clutch switch, which some cars don't have and needs to be retrofitted. The wire is there but the switch is not. You need to check
  3. Re: Cruise control retrofit wire to ecu?
    Jan 2012
    Coding Something
    Wire is fitted to all B7's.
    B6/7 uses Kline for diagnostics & some comms, Canbus is used for comms between modules only, no diagnostics afaik.
  4. Re: Cruise control retrofit wire to ecu?
    May 2013
    England
    Quote Originally Posted by NHN View Post
    Thanks for that so do you mean they already have the wire fitted or that one needs to be put in. Mines a trip tropic if that makes any difference atall
  5. Re: Cruise control retrofit wire to ecu?
    46 Post(s)
    Wire is fitted.
  6. Re: Cruise control retrofit wire to ecu?
    Aug 2013
    United Kingdom
    Literally all you need for cruise control is the stalk and VCDS. Nothing else.
  7. Re: Cruise control retrofit wire to ecu?
    May 2013
    England
    Thanks for all the help everyone, really looking forward to installing all this now
  1. Question Cruise Control Retrofit
    By jonathanfenton in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-05-2012, 10:52 AM
  2. cruise control retrofit
    By burkey1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-05-2012, 07:09 PM
  3. Retrofit cruise control
    By racman5487 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-07-2009, 11:44 AM
  4. Retrofit Cruise Control
    By trainer555 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2009, 09:15 PM
  5. Cruise Control Retrofit
    By Greenfield in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2008, 12:59 AM
