Thread: illumination
  1. illumination
    Sep 2007
    how much hard work is it to sort illumination out for the heater dials in my 2000(w)bora
  2. Re: illumination
    how you mean , is the light not coming on around the turn switches?
    if its this , just pull of the knobs then the clear plastic peice then you can get et the bulb
  3. Re: illumination
    Sep 2007
    if its that simple will give it a shot,was told by the garage i bought it off that the center console had to come out and some other bits
    cheers for the input mate
    mick
  4. Re: illumination
    Just done mine tonight,
    1. Set fan speed control dial to '2'
    2. Pull fan speed control dial off
    3. Long nose pliers to remove bulb (its a capless bulb)
    4. UK replacement bulb is known as R286
    5. Replace bulb with long nose pliers.
    6. Replace knob.
    Strandard long nose pliers are too large, i borrowed a small set from a mate, i reckon i could've got away with a set of tweezers.
    Only one bulb to replace, it lights the others too
    Ten minutes tops!
    Hope this helps
    Regards
    Butch
  5. Re: illumination
    Sep 2007
    butch
    cheers for the input mate,already sorted mate in like bya say 10mins
    cheers
    mick
  1. Instrument panel illumination light problem... or "I can't see how fast i'm going at night!"
    By rbaulcombe in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-08-2007, 07:44 PM
  2. Interior Illumination Problem
    By rhinopower in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-06-2007, 11:48 PM
  3. check brakes illumination
    By fozzie in forum Passat - Archive Topics
    Last Post: 29-03-2007, 09:28 AM
  4. Climatronic illumination
    By dickturpin in forum Passat - Archive Topics
    Last Post: 28-03-2007, 02:20 PM
  5. Dash illumination
    By t0m541 in forum Audi A3 - Archive Topics
    Last Post: 21-03-2007, 09:28 AM
