Thread: Only reaching 70 degrees after Coolant Sensor replacement
  1. Only reaching 70 degrees after Coolant Sensor replacement
    Jan 2009
    I while back I replaced the G2 Coolant Sensor in our A4 1.9TDI, as it was never getting above cold on the temp gauge. This seemed to solve the problem but it now only ever reaches 70 degrees, whereas the car originally used to sit dead centre at 90 degrees. The replacement is a green sensor opposed to the original black one. My only concern is that the MPG won't be as it should be now if the car is always running cooler than it should? Any suggestions?
  2. Re: Only reaching 70 degrees after Coolant Sensor replacement
    Dec 2007
    8 Post(s)
    Probably thermostat replacement next option.
  3. Re: Only reaching 70 degrees after Coolant Sensor replacement
    Apr 2013
    gosport uk
    I had the same thing happen. I replaced the sensor with a genuine replacement and the gauge still did not reach 90. I changed the thermostat and bingo,sits at 90 all day.
  4. Re: Only reaching 70 degrees after Coolant Sensor replacement
    May 2011
    Enniskillen Co,Fermanagh
    Quote Originally Posted by a4cvt View Post
    same happened with me last year
    Remapped 2004 130 sport
  5. Re: Only reaching 70 degrees after Coolant Sensor replacement
    Oct 2013
    belfast
    as said above go genuine all the time. plus probably time for a new thermostat. go genuine
  6. Re: Only reaching 70 degrees after Coolant Sensor replacement
    Jun 2006
    Cardiff
    Quote Originally Posted by ck_uk View Post
    Was the replacement sensor genuine VAG? If it was then you probably have a stuck open stat or an air lock.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  1. Cold running ...70 degrees coolant
    By Robnelson76 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-01-2015, 08:25 PM
  2. Coolant Temperature Sensor Replacement Guide
    By mike777 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-02-2011, 10:13 AM
  3. Not reaching 90 degrees
    By PassSPORT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-02-2010, 11:47 PM
  4. Loosing power after reaching 90 degrees
    By rayTTsmith in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-06-2009, 08:13 AM
  5. Coolant Sensor replacement - Codes?
    By Laurie2212 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-08-2008, 02:53 PM
