Thread: 18 replica rotor style wheels
Results 1 to 9 of 9
  1. 18 replica rotor style wheels
    Feb 2014
    cumbria
    Any one have any experience of the rotor style replicas? i want to run 18 winter wheels and tyres for 4 months in winter. Also has anyone fitted 18 wheels on a c7 Bitdi s line be ? ie, no problems with clearance on callipers.
  2. Re: 18 replica rotor style wheels
    Jun 2008
    The standard S-line alloys are 18" 5-twin spokes so it shouldn't be a problem but replicas are generally pretty pants and you will have to tell your insurer if you fit non-OEM wheels to your car.
    i've generally found that it's very nearly as cheap to buy the genuine article used from German eBay or forums like these as it is to buy replicas.
    if you REALLY want replicas then the only ones to get are WSP Italy. They are officially pattern parts like the brake pads and exhausts that you get for cars. They are certified as replacements for the OEM wheels and WSP Italy are very keen to tell you all about how they are not replicas but replacement parts on their website. And they're a lot cheaper than the genuine article.
    CERCHI IN LEGA WSPITALY
  3. Re: 18 replica rotor style wheels
    Jun 2012
    6 Post(s)
    Quote Originally Posted by bergboxer View Post
    Nothing will trash the residual value harder than a set of aftermarket wheels, apart from matt black vinyl wrap perhaps. What is this fascination with Rotor Wheels? It takes a svelt, stylish executive car and turns it into Huggy Bears pimpmobile
    0 0 1
  4. Re: 18 replica rotor style wheels
    Feb 2014
    cumbria
    if
    Quote Originally Posted by rickerby View Post
    If you read the article , you will read that i want to run 18 wheels with winter tyres, if you have ever spent any time driving in snow and ice , you would know that 20 wheels and rubber bands are as much good as a chocolate fire guard.
    the reason for the rotor style wheel would look similar to the 20 original ones.
  5. Re: 18 replica rotor style wheels
    Dec 2010
    CD UK
    6 Post(s)
    Maybe, but there's no suggestion that the OP is looking to sell his car either with or without original wheels.
    My view is if you're happy to run around on aftermarket wheels and the wheel/tyre combo costs the same or less than replacing the original tyres - why not? If your car is on a PCP then you can refit the originals if returning the car. The other set can be sold or reused perhaps for winter use. That's what I did although I've retained the car and not returned it.
    I'm not suggesting that replicas are good (I'd rather buy OE or aftermarket from an OEM), but if you like the look, they're safe and you've disclosed it it your insurers I don't see a problem
  6. Re: 18 replica rotor style wheels
    Feb 2014
    cumbria
    Thats why i ask the question if any one has had any experience with replica wheels, as you know with winter tyres they have a reduced speed rating so i would not be high speed cruising or doing a track day. This car i will keep for at least 5 years, if it behaves itself, my previous car was 9 years old ,when i replaced it with this one, and i had a spare set of winter wheels and tyres which went on in december and came off in march, we get a bit of snow up north, winter tyres just work so much better in cold wet weather anyway.
    As i will probably keep this for a while , i will look on ebay. de as wja96 suggested and have some sent over.
  7. Re: 18 replica rotor style wheels
    Jun 2008
    OK, I had very little better to do while I wait for my pizza to cook, so I had a quick look and WSP do the homologated Rotor wheel in 17, 18, 19 and 20 inch versions. All the rim diameters are available in the 66.6mm centre bore required and the correct 5x112mm bolt circle (PCD). I am not sure what the OEM offset (ET) is but I reckon 43 should be perfect. WSP call the rotor "Giasone".
    typing WSP Giasone ET43 into ebay.co.uk with worldwide and description search turned on yielded returns on 17-20" sizes but as the OP wanted 18" I picked these as the cheapest ones with the traditional Titan finish and polished edge.
    Cerchi in lega WSP Italy W567 Giasone MGMPolished 7.5x18 5x112 ET43Audi Q5 S4 S6 | eBay
    Also in 17" which should clear the brakes on the S-line.
    http://www.ebay.co.uk/itm/Cerchi-in-...item3f26157079
    they're not £500 a set, but they are OEM quality and the finish won't come off after 1 winter. You can also get a nice simple silver finish that also works well.
    19" wheels are only about £15 each more and 20" are about another £25 on top of that.
    have fun!
  8. Re: 18 replica rotor style wheels
    Feb 2014
    cumbria
    Thanks for your attention , you certainly know your stuff. cheers
  9. Re: 18 replica rotor style wheels
    Jul 2011
    manchester
    I have run replica rotors on my a4 for a year, I recently went down a monster pothole, trashed the tyre, small dent in the rim, otherwise ok,recently I had a puncture repaired on the wifes' cc, genuine turbine pattern, guess what? buckled, checked the rest, another one buckled, so my conclusion based on experience is that replicas can be as good if not better than some oe wheels. Hope this helps.
  1. 20'' Rotor Arm Wheels out of stock
    By birdmansa6 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-06-2013, 10:19 PM
  2. Replica Wheels
    By Bratty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-03-2010, 11:59 AM
  3. Replica Alloy Wheels
    By sooty in forum Chat - Anything with wheels
    Last Post: 24-09-2009, 09:09 AM
  4. 19" RS4 Replica wheels + remap
    By FSI Turbo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-01-2009, 10:16 PM
  5. Replica Wheels
    By Ads1999uk in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-08-2008, 09:12 AM
