Thread: Acceleration lag following gear change
  1. Acceleration lag following gear change
    Mar 2008
    Strange one here folks. 2.0 TDI. Starts and runs fin from cold. Once regular operating temp is reached, something funny happens. Under acceleration, and immediately following gear change, there is a momentary lag, and then its fine. Really noticeable from 1st to 2nd, and 2nd to 3rd. Say your at 2,500 RPMs and you clutch to change into 2nd, once you come off thte clutch, at that time when you press on the gas, the lag occurs. It is visible on the revs counter: you can see a sharp drop of 200rpms approximately and then she will pick up. Only happens when warm, and is continuous. Any ideas ?
  2. Re: Acceleration lag following gear change
    46 Post(s)
    Have you had a fault scan with VCDS or Audi? When was the car last serviced?
  3. Re: Acceleration lag following gear change
    Mar 2008
    No logged error codes Chris. Serviced recently. Just a niggly thing I'd like corrected.
  4. Re: Acceleration lag following gear change
    Sep 2013
    Measham, UK
    Quote Originally Posted by dodzy View Post
    I may be wrong, but as far as I know it's normal on the TDI. The turbo kicks in around 2,000rpm, so when changing gear, you lose the revs (as you should) which may put you under this threshold. I guess it may be just good old turbo lag? Best thing to do, boot it up to 3000rpm then change, you miss the crossover rpm then
    EDIT: Oh, and I think the max power on the curve of the engine is around 3,500 - 4,000rpm ( depending on map, or standard map) so you won't be using all your grunt down in 2,500rpm anyway!
    Audi A6 2.0 TDi S-Line Special Edition (60 Reg) Phantom Black
  5. Re: Acceleration lag following gear change
    Mar 2008
    Quote Originally Posted by Owendavies View Post
    thanks for the input Owen, but it is an error. Definitely only occurs when engine reaches operating temp and even then, there will be periods where it's not there. You can feel the difference definitely, and there is an accompanying visual drop on revs counter also.
  6. Re: Acceleration lag following gear change
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    If you have VCDS try checking the clutch switch values change when depressed, just to check its not causing an issue.
    Alan.
    VW T6 150 DSG Camper £££
  1. 1st gear acceleration issue
    By bloostar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-06-2010, 06:11 PM
  2. Please Help Over Revving on Gear Change/Acceleration
    By EJC in forum Alhambra
    Last Post: 18-09-2009, 07:48 AM
  3. audi A6 2.0tdi 1st gear acceleration
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 24-05-2009, 09:38 PM
  4. 1.9TDI hesitation mid- 2nd & 3rd gear acceleration HELP!
    By horacek in forum Chat - Anything with wheels
    Last Post: 09-07-2008, 11:26 AM
  5. Audi A4 2.5 TDI acceleration lag / slow to pick up power
    By toddywoody in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-05-2007, 04:00 PM
