Thread: Retrofit Lane assist
Results 1 to 8 of 8
  1. Retrofit Lane assist
    Feb 2014
    norway
    Hi all
    As the title say I will have one more try in getting this up and running.
    I have the ACC camera in the windscreen, witch I believe will do the reading of the lines in the road.
    I will have to get the blinker stalk with the "enable line assist button in the end of it.
    I do not intend to get side assist, so no need for the mirrors to be swapped.
    My question is if anyone know what I'm missing to get this working?
    I assume one stearin wheel module, to intersept steering wheel angles, and maybe do the direction change if drifting out of lane.
    I assume one module to proses and interpret the camera input for this purpose.
    And obvious coding :-)
  2. Re: Retrofit Lane assist
    Nov 2013
    London
    Have to ask why bother? First day of A7 ownership switched it off and never used it again. Have friends who did exactly the same. It's like driving with a flat tyre. Other than that good luck!
    A7 BiTDI SE, Ice Silver, Tech Pack Advanced, Comfort Pack, Audi Connect, Google Earth Map, Massaging/Vent Seats, 4 zone ACC, Adaptive Cruise, Power doors, Heat/Sound Insulating Glass, 19" 10 spoke, Advanced Key, Electric Steering Column, Ski Shute and bag, Folding mirrors, Rear camera, makes you smile every drive
  3. Retrofit Lane assist
    Feb 2013
    Gloucester
    57 Post(s)
    I use it on motorways and it's brilliant. As the steering turns back into the lane and vibrates, I think you will need some form of electric motor for these functions.
    Which country are you in?
  4. Re: Retrofit Lane assist
    Feb 2014
    norway
    Quote Originally Posted by M1tchy View Post
    I'm in Norway :-)
    I assume the steering is done by the elecktro mech. steering.
    Was hoping to be able to skip the vibrating motor in the steering wheel, is it important for the experience?
    I know now that the camera will pick up the lanes, so that is in place, i need someone with vcds to do a scan of all the modules,
    so I can compare with mine, to see what modules is missing. :-)
  5. Re: Retrofit Lane assist
    Feb 2014
    norway
    Quote Originally Posted by soft View Post
    I'm in Norway :-)
    I believe the path is as follows:
    ACC camera -> Image processing module (not present) ->Steering control module (not present) -> Electric steering module
  6. Re: Retrofit Lane assist
    Feb 2013
    Gloucester
    57 Post(s)
    If you PM me your email address I will send you a VCDS scan of my car which has lane assist fitted
  7. Re: Retrofit Lane assist
    Feb 2014
    norway
    cool :-)
  8. Re: Retrofit Lane assist
    Feb 2014
    norway
    New info,
    the only item that seems to be different is this:
    Address 3C: Lane Change Labels: None
    Part No SW: 4G0 907 566 J HW: 4G0 907 566
    Component: J769 SWA MasterH04 0060
    Revision: 00H04000 Serial number: 6PZ 010 287-08
    Coding: 0001107
    Shop #: WSC 02391 785 00200
    VCID: 36685D574130B9AE71B-8063
    Subsystem 1 - Part No: 4G0 907 568 J
    Component: J770 SWA Slave H04 0060
    Subsystem 2 - Serial number: 6PZ 010 287-28
    Subsystem 3 - Serial number: 5F04.09.1300H04000AMS16842ÿ
    Subsystem 4 - Serial number: S16842ÿ
    In terms of HW this seems to be the detectors in the back, for SIDE ASSIST, and dont have to do with lane assist.
    It seems to be harder to find out about the subsystems....
  1. ACC - Automatic go, increase to 3 minutes? Also Lane assist...
    By razor77 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 21-10-2013, 06:30 PM
  2. lane assist (crosspost)
    By lozzer in forum Golf MK7 - 2013 - 2019
    Last Post: 16-06-2013, 08:55 AM
  3. lane Assist (crosspost)
    Last Post: 25-03-2013, 09:23 PM
  4. Replies: 0
    Last Post: 26-04-2012, 10:45 AM
  5. Retrofit front park assist?
    By avant_adam in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-10-2009, 12:40 PM
