Thread: Audi a4 1.8t oil warning light on after replacement pump
  1. Audi a4 1.8t oil warning light on after replacement pump
    May 2014
    Taunton uk
    Hello all, I'm new to this forum and I'm needing help with this reoccurring problem...
    last year my oil light came on and my car broke down I recovered it to my local garage where the mechanic had to fit a new oil pump and pipe! About 2 weeks later the light started flashing every so often so I took it back and he fitted a new sensor and flushed, the car then seemed fine for a while but every so often the light would flash so I just figured the car was burning a lot of oil and topped it up and the light would go away for another month or 2..
    Any way a year on and the light started coming on again every 5-10 minutes so I returned it to the garage and my mechanic flushed the engine and fitted a new sensor which had little affect. So again I returned the car and this time he fitted a new oil pump and oil feed hose! I drove the car for about 20 miles and the light is still coming on but going straight out and it almost seems that if I apply more power the light goes out quicker... I have no idea now and neither does my mechanic can any one help me out?? Thanks
  2. Re: Audi a4 1.8t oil warning light on after replacement pump ;((
    Oct 2005
    Welcome to VWAF
    What colour is the oil light, orange or red?
    Is it flashing or illuminating and going out later?
    Is it using oil?
    Was the oil pick up pipe/strainer checked?
    Were all replacement parts new and genuine?
  3. Re: Audi a4 1.8t oil warning light on after replacement pump ;((
    Mar 2008
    Just Cumbria now.
    Welcome to VWAF
    Is it using oil?
    And have you had a fault code read?
    Nothing to see here, move along..
  4. Re: Audi a4 1.8t oil warning light on after replacement pump ;((
    Oct 2005
    Quote Originally Posted by Hex69 View Post
    Good catch!
    I always assume, as the car has been to a professional, that this would have been done already.
  5. Re: Audi a4 1.8t oil warning light on after replacement pump ;((
    Mar 2008
    Just Cumbria now.
    Good catch!
    As they always say, "never assume, as it makes an *** of 'u' & me!"
    Bloody swear filter won't let me write about the union of a donkey and a horse!
  6. Re: Audi a4 1.8t oil warning light on after replacement pump ;((
    May 2014
    Taunton uk
    Hi there the oil light is red and it flashes bleeps and then goes out and then two minutes later it comes on again! Yes the car is using oil the mechanic said oil is definitely getting around. The pick up pipe was checked but thinking back I don't thing the part was genuine I will follow that up now
  7. Re: Audi a4 1.8t oil warning light on after replacement pump ;((
    131 Post(s)
    1976 Post(s)
    STOP. The "mechanic " should first of all carry out an oil pressure check using a gauge and not guess! If the system was full of gunge and not properly cleaned out, new oil can make this gunge come down and block the pick up or over enthusiastic sealant use can also cause this as I saw on one I had in below
    It should be applied like this and the sump as clean as this one I did using paint stripper as usual.
    0 2 0
  1. Replies: 301
    Last Post: 07-08-2017, 11:45 PM
  2. Question Oil Pressure Warning Light - assumed oil pump fault. Advice and expected cost.?
    By dijjital in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2017, 07:37 PM
  3. Please Help 2002 Audi A4 1.8t Oil warning light after 5 mins of driving then engine management light comes on
    By ScottyDoo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-09-2013, 01:02 PM
  4. Audi A6 oil warning light
    By daz the audi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-05-2008, 09:06 AM
  5. Audi A6 oil light warning
    By daz the audi in forum New Member Introductions
    Last Post: 28-04-2008, 09:17 PM
