Thread: Front caliper brake hose
  1. Front caliper brake hose
    Apr 2011
    Blackburn, UK
    Anybody know whether there is a washer on the bolt holding the hydraulic brake hose to the caliper on 2004 Mk5 GTTDi?
  2. Re: Front caliper brake hose
    135 Post(s)
    2040 Post(s)
    Yes there is one either side of the fitting but you cannot buy the bolt or the washers from VW so we re-use the bolt (carefully cut the old washers off) and fit copper washers.
  3. Re: Front caliper brake hose
    Apr 2011
    Blackburn, UK
    Thanks for that Crasher, that could present a problem if the washers cannot be sourced from VW! I can get some copper ones from work but I would need to know the ID and OD and thickness and I don't want to take the originals off until I have all the bits. Any idea on the sizes of the washers matey or if they can be sourced elsewhere?
  4. Re: Front caliper brake hose
    135 Post(s)
    2040 Post(s)
    The banjo bolt is M10 and has a shoulder under the head before the fluid passage under cut which is 9.9-mm in dia so a washer with an ID of 10-mm minimum would be needed. The copper washers we use have an ID of 10.30-mm an OD of 14.88 and are 1.7-mm thick, so they are slightly baggy on the OE banjo. These are what the Goodridge hoses use so we have a bag full as people lose them.
  5. Re: Front caliper brake hose
    Apr 2011
    Blackburn, UK
    Perfect, thanks Crasher.
  1. Scirocco front brake caliper torx size.
    By gord115 in forum Scirocco - 2008-
    Last Post: 09-09-2013, 05:18 AM
  2. Front brake caliper- wire clip.
    By Redders2 in forum Golf MK5 - 2004 - 2009
    Last Post: 22-06-2012, 09:16 PM
  3. Please Help NS Front Brake not working, though caliper not seized
    By leeoz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-04-2012, 05:43 PM
  4. A6 Front Brake Pad and Caliper Rattle
    By lee1157 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-05-2010, 10:46 AM
  5. a4 b6 2002 1.9 tdi front brake caliper bolt stuck !
    By granite-silver in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-01-2009, 01:51 AM
