Thread: BLB engine too hard to start... but after starting the next start is normal..
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: BLB engine too hard to start... but after starting the next start is normal..
    Jul 2013
    oaz
    my blb engine is 2.0 tdi 16v with bosh injectors, and i have to solve this issue now, because sometimes, instead of paying to some guys, its better to put our own hands on work...
    I've already purchased new sets of screws for the injectors and for the cam, and before buy the seal kits... in all the images of kits of ebay.... i see a weird thing!!!
    Is not supposed to have copper washers to seal between the engine head and the injector?????
    There is no kits for 2.0 tdi 16v engine with copper washers!!! is this normal??? ,only 2 plastic seals with top pin and gasket???
    please help
    regards
  2. Re: BLB engine too hard to start... but after starting the next start is normal..
    Sep 2008
    mostly in the garage
    Before you pull the injectors you should try to establish if they are actually at fault.... if the issue is low fuel pressure it could also be a faulty tandem pump or possibly even the delivery pump in the fuel tank.
    A dealer or specialist would test with a pressure gauge at the tandem pump. If pressure is being lost into the return line via the injector seals squeezing off the return line to restrict return flow should increase the pressure reading. Maybe you could test by sqeezing off the return between tandem pump and filter and see if this makes the car start easier?
    The injectors have a tapered seat into the cylinder head so no copper washers in this application....the tapered seats need to be clean and inspected for damage before refitting the injectors.
    1 1 0
  3. Re: BLB engine too hard to start... but after starting the next start is normal..
    Jul 2013
    oaz
    hello again..
    the start of the car starts much more easier, if i squeeze the return diesel line beetwen the tandem pump and the filter!
    what could this mean??
    injector seal problem?
  4. BLB engine too hard to start... but after starting the next start is normal..
    46 Post(s)
    Right to me, I could be wrong but if the first start is hard (ie no fuel pressure) but the second start is ok, that suggests to me like its fuel pump related like chaser has said above.
    Get the car to a specialist, you'll be here forever narrowing things down if you don't.
    After this fix it and sell it.
  5. Re: BLB engine too hard to start... but after starting the next start is normal..
    Sep 2008
    Quote Originally Posted by matrixpt View Post
    hello again..
    it would be better to have actual pressure reading but it suggests that fuel pressure is passing from the supply to the return side via the injector seals.
    1 1 0
  6. Re: BLB engine too hard to start... but after starting the next start is normal..
    Jul 2013
    oaz
    Quote Originally Posted by c4a5er View Post
    After making a homemade pressure reader, checked the pressure at 4000rpm and the values are according with the specs.... and after this, i replaced all the injector seals and injector bolts, according with the documentation and also starter brushes....
    now it runs smoothly and without any problem...
    Many thanks to everyone, specially to c4a5er and A6_Chris
    Last edited by matrixpt; 28-05-2014 at 11:06 PM. Reason: adding thanks to the team
    2 1 0
  7. Re: BLB engine too hard to start... but after starting the next start is normal..
    #17
    Sep 2008
    After making a homemade pressure reader, checked the pressure at 4000rpm and the values are according with the specs...and after this,
    A good result...thanks for the update.
    The issue is/was the time taken to build pressure at cranking speed rather than the pressure once running. Once running a healthy tandem pump can keep up with the lost pressure at the seals at least until it worsens and causes poor running.
    1 1 0
  1. Question Sharan 2005 TDI loss of power and hard to start when warm starting
    By macka001 in forum Touran - Sharan - Caravelle
    Last Post: 16-06-2015, 08:23 AM
  2. Cold start issues - 2.0 140bhp BLB engine
    By fkgti in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-10-2013, 04:29 PM
  3. 2.5 TDI AYM engine Hard starting now wont start
    By westfield1962 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-09-2013, 10:25 AM
  4. Replies: 8
    Last Post: 16-10-2012, 09:18 PM
  5. Hard to start Engine in the morning everyday
    By Laurence Tsai in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 11:31 AM
