Thread: BLB engine too hard to start... but after starting the next start is normal..
Results 1 to 10 of 17
  1. BLB engine too hard to start... but after starting the next start is normal..
    Jul 2013
    oaz
    hello to all.
    i'm facing more problems with my 2.0 blb engine.... after all the money i spent rebidding the engine and changing the oil pump, now it takes more than 30-40 seconds to start and after the start, if i shut down the engine just after..... it will start right away...
    i'm afraid to damage the starter, but...
    When i turn the key on the car the glow plug resistance light is only shown near 2 seconds and goes off. - outside temperature between 24-25șC..
    my ideas about possible component failure:
    1- n75 valve not working??
    2- g62 - coolant temperature sensor affecting the time of the glow plugs??
    3- injector's problems????
    Any ideas???
  2. Re: BLB engine too hard to start... but after starting the next start is normal..
    46 Post(s)
    Any fault codes?
  3. Re: BLB engine too hard to start... but after starting the next start is normal..
    Jul 2013
    oaz
    on vcds no dtc is shown... on engine module.
    this engine was rebuilded because i've suffered a major accident, and n75 valve was totally damaged, and the coolant plastic housing (- g62 sensor) was severely damage also...
    The repair guy, replaced only the plastic housing of the (g62 sensor is the same)...
    The original n75 that is broken has the sn 8E0906627c and the guy installed one with the code 8E0906627a...
    maybe this??
  4. Re: BLB engine too hard to start... but after starting the next start is normal..
    46 Post(s)
    So he's installed an older part than previously fitted.
    Get a new one from Audi by your vin number.
  5. Re: BLB engine too hard to start... but after starting the next start is normal..
    Jul 2013
    oaz
    and can this be the reason of this so difficult start engine?
  6. Re: BLB engine too hard to start... but after starting the next start is normal..
    46 Post(s)
    Could be. Not saying it is but don't ever use older revisions of parts that were fitted before.
  7. Re: BLB engine too hard to start... but after starting the next start is normal..
    Southern County Softy
    20 Post(s)
    Disconnect yhe coolant temp sensor and see if it starts any easier.
    Sent from my GT-I9505 using Tapatalk
    A4 2.5 tdi QS (mapped)
  8. Re: BLB engine too hard to start... but after starting the next start is normal..
    Jul 2013
    oaz
    without coolant sensor is the same thing!
    The glow plug light is on only for max 2 seconds and the engine takes like i said on first post more than 30-40 seconds.... to start
  9. Re: BLB engine too hard to start... but after starting the next start is normal..
    Sep 2008
    mostly in the garage
    Quote Originally Posted by matrixpt View Post
    hello to all.
    Any ideas???
    could be that it's taking time to build fuel pressure.......fuel pump/tandem pump...injector seals?
  10. Re: BLB engine too hard to start... but after starting the next start is normal..
    Jul 2013
    oaz
    hello again!
    i know that the guy replaced the seals.... but he used the same screws..... maybe that's it???
  1. Question Sharan 2005 TDI loss of power and hard to start when warm starting
    By macka001 in forum Touran - Sharan - Caravelle
    Last Post: 16-06-2015, 08:23 AM
  2. Cold start issues - 2.0 140bhp BLB engine
    By fkgti in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-10-2013, 04:29 PM
  3. 2.5 TDI AYM engine Hard starting now wont start
    By westfield1962 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-09-2013, 10:25 AM
  4. Replies: 8
    Last Post: 16-10-2012, 09:18 PM
  5. Hard to start Engine in the morning everyday
    By Laurence Tsai in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 11:31 AM
