Thread: Noisy R Line
Results 1 to 10 of 14
  1. Noisy R Line
    Apr 2010
    uk
    The old b5 highline was replaced with a 59 R Line 110 diesel Passat with 50000 miles and it's taking a bit of getting used to as there seems to be a bit of noise over 20mph, just as if something is resonating but it does not get any worse with increasing speed. New mot so there should not be any worn bearings, 235 45 r 17 tyres are all Pirelli, p zeros which have about two thirds left on the back and new cinturatos on the front.
    Anybody else find the R line noisy ??
  2. Re: Noisy R Line
    Nov 2009
    46 Post(s)
    Does it happen at the time?
  3. Re: Noisy R Line
    Apr 2010
    uk
    Seems to be there all the time but this afternoon I had a rake around in the boot and found that the spare wheel was not secured as it should also the cover for the jack had only one of the hold down tabs secure and there was a first aid box loose too so all was secured as they should and it made no difference but it sure is a noisy beast compared with the old highline. Maybe the size of the tyres has a lot to do with the racket as I have never had a car with suck wide boots.
    Just checked all the tyre pressures and noticed that the tracking is out a little.
  4. Re: Noisy R Line
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The rear tracking is sometimes out slightly on these cars which develops a sawtooth edge on the rear tyres.
    Try brushing your hand over the tyre treads in both directions, especially either the inside or outside edge.
    If it feels rough in one direction, that will probably be your problem.
    Will need tracking corrected & new tyres if that is the case.
  5. Re: Noisy R Line
    Apr 2010
    uk
    I had the tracking done today but not at a vw garage, it's still noisy, freewheeled down a nice long hill at 30mph and still noisy but I will check the rear tyres tomorrow, maybe even swap front to back later in the week, just spent some time trawling the web and I am not the only one with a noisy Passat. I am way too mean to put two new tyres on as there is still 2/3 left in the rears.
    The resonating racket is really taking the pleasure out of driving the car and I have only had it three weeks.
  6. Re: Noisy R Line
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    If the tyres have already developed a sawtooth to the tread, correcting the tracking won't get rid of the noise.
    You could try swapping to the front, perhaps NSR to OSF & OSR to NSF, then tyre would be rotating in the opposite direction.
    Maybee worth a try.
  7. Re: Noisy R Line
    Apr 2010
    uk
    Success, rear wheels switched over with the front = no resonating although there is a little noise from the front end and yes the edges of the rears were feathered slightly.
    Contentment at last.
  8. Re: Noisy R Line
    Apr 2007
    France
    12 Post(s)
    Have you had the rear tracking checked? If not you'll have the same problem with the rears feathering again.
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacré | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  9. Re: Noisy R Line
    Apr 2010
    uk
    Not sure what they did so I will have to go back and find out on Monday, probably only done front.
  10. Re: Noisy R Line
    SE London
    And I hope you're using a laser tracking fitted shop such as a Hunter franchise?
    You'll need all round -- it's the rear camber that goes out
  1. Replies: 29
    Last Post: 02-10-2013, 10:59 PM
  2. 2012 A5 s-line wheels for 2008 A4 S-line
    By sacha35 in forum Wheels and Tyres
    Last Post: 04-11-2012, 08:30 PM
  3. Please Help a4 s line diesel manual 2010 plate fan staying on !! / a4 s line special addition spec ??
    By garry5510 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-02-2012, 06:36 PM
  4. Please Help Low Line to High Line Mod - can't code the power supply unit
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2010, 02:25 PM
