Thread: High Pitched Whirring Noise from Engine
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. High Pitched Whirring Noise from Engine
    May 2014
    York
    I have a 2.0 TDI Sport Passat B6.
    I have noticed that there is a high pitched engine noise (mainly in the first few gears) coming from the engine, it sounds very similar to a siren from a police car.
    Need help as to what the problem is?
  2. Re: High Pitched Whirring Noise from Engine
    May 2014
    York
    Any help?
  3. Re: High Pitched Whirring Noise from Engine
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Most likely to be the turbo, with road noise drowning it out in higher gears.
    Does the sound vary with throttle input rather than engine revs or road speed.
  4. Re: High Pitched Whirring Noise from Engine
    May 2014
    York
    Yeh it does, what would be the best thing to do to try and reduce the noise?
  5. Re: High Pitched Whirring Noise from Engine
    134 Post(s)
    2022 Post(s)
    The turbo needs a rebuild. If you ignore this problem it can fail catastrophically and mean the repairs cost much more.
  6. Re: High Pitched Whirring Noise from Engine
    May 2014
    York
    Any idea of how much it would cost to be rebuilt?
  7. Re: High Pitched Whirring Noise from Engine
    vespa Guest
    From what I gather £600-£1000 depending on where from. Please read the RAC website reconditioned-engines.co.uk aka brentsouth trading aka heathrow engines DO NOT USE and this 1st choice engines Just in case you live near there.
  8. Re: High Pitched Whirring Noise from Engine
    134 Post(s)
    2022 Post(s)
    With us the job typically comes out at around £850 including an oil and filter change as long as the turbo is repairable and there is no system debris contamination AND as long as the oil pipe does not stick and snap!
  9. Re: High Pitched Whirring Noise from Engine
    May 2014
    York
    Is there any idea as to how long I have until it goes?
  10. Re: High Pitched Whirring Noise from Engine
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Some last for years & another will fail the next time you start the engine. So best change it ASAP.
    But as Crasher says, depending how it fails, it could kill your engine which will be much more costly.
    There is a company on eBay that supplies new CHRA assemblies ( the part of the turbo that wears out ) at good prices.
    passat chra from nerings | eBay
    You would have to check the part No of your existing one carefully & find a local garage to fit it if you're not into DIY.
  1. High pitched noise and reduced boost
    By dtwoi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2013, 08:54 PM
  2. high pitched noise from new A6
    By weegie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-08-2011, 09:37 PM
  3. White smoke and high pitched engine noise...
    By Jonny Chee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2011, 05:13 PM
  4. High pitched noise when driving
    By random_dave_1 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-03-2008, 09:14 PM
  5. High pitched noise at startup
    By namaste9 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2008, 08:45 PM
