Thread: Retrofit Oem Bluetooth 2009 A4 Avant
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Retrofit Oem Bluetooth 2009 A4 Avant (Now Completed)
    I am ready to do this retrofit but need to be 100% sure I am buying the right hardware.
    I have a concert Radio with NO Nav.
    I assume I need the bluetooth module with antenna, mic and a wiring loom.
    I have Vagcom so can code it myself.
    If I buy one from Ebay will it have component protection and I need to visit Audi to remove it? If so how much does it cost.
    Below are link to what I believe I need hardware wise.
    Can someone confirm if this is correct.
    Also I want it to work with an iPhone 5s so will the "D" revision support this.
    I want the OEM so i can use the voice dial button on the steering wheel rather than scrolling through the menu etc.
    *AUDI A4 B8 2008-CURRENT INTERFACE BOX FOR BLUETOOTH 8T0862335D | eBay
    Audi Bluetooth SDS Wiring A3 A4 â–º RNS-E Concert 8P1862335 8P0862335 8T0862335 | eBay
    2009 A4 Avant 3.0Tdi Quattro.
    2012 A1 TFSI 185bhp (Mrs Car)
    VCDS Owner
  2. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    46 Post(s)
    No component protection on BT modules so you're fine there.
    That module is from 2010, iPhones were out since then so I'd be pretty sure it'll be compatible.
    The mic you need is 8L1862373A.
    Wiring loom is correct so you're good to go.
  3. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    Thanks Chris, I will get it ordered then have a stab at fitting it myself. Do you know where the BT module sits within the car?
    VCDS Owner
  4. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    46 Post(s)
    OEM position would be below the carpet below the front passenger seat but if you're wanting to put it there then you'll need this longer loom - Audi Bluetooth Plug&Play Wiring + SDS - 220cm
    You should be fit to install it behind the glovebox somewhere. You'll need this link A4 B8 Stereo Removal to remove the headunit.
  5. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    Would this complete solution be ok. Works out about £300 delivered but looks like a brand new kit with loom and mic.
    Audi Bluetooth 8T0862336 E - Upgrade Kit -
    VCDS Owner
  6. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    46 Post(s)
    Yeah suppose it would be, just your decision whether you want the longer loom or not.
  7. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    Thanks Chris, you are a mind of information.
    I would be happy to keep the module behind the glove box. My only question is If the one in my last link from Carsystems is a genuine Audi Oem or a copy of it.
    Decisions, decisions.
    VCDS Owner
  8. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    46 Post(s)
    Genuine, can't get copy BT modules lol
  9. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    Cheers, I was thinking they could be like the Fiscon modules
    Your help has been fantastic mate
    VCDS Owner
  10. Re: Retrofit Oem Bluetooth 2009 A4 Avant
    46 Post(s)
    Fiscons are small black boxes so no need to worry there.
    You're welcome!
  1. OEM Bluetooth Retrofit for 53reg Passat?
    By carbers911 in forum In Car Entertainment
    Last Post: 18-06-2013, 01:45 AM
  2. OEM retrofit anyone heard of used them?
    By unphased matt in forum In Car Entertainment
    Last Post: 09-06-2010, 10:20 AM
