Thread: Double Din, headunit adapter/fascia kits?
  1. Double Din, headunit adapter/fascia kits?
    May 2014
    Northants
    Hi everyone!
    This is my first post on the forum, and I've joined mainly for help on this question alone... But after having a quick browse through the forums, I'm sure I could learn a lot more than what I first signed up for, and make my B5 estate the car I want it to be
    I currently have the standard 'Concert' head unit in place, but would like to replace it for a fancy 'Double din' 7" touchscreen jobby if possible. But with the space Being minimal from the Air conditioning controls up to the hazard light switch I'm wondering how this could be done?
    I've seen tonnes of Backing plate & fascia conversion kits on the web tonight, but none specifically for my car (1999/B5 A4 Avant Tdi Estate) and knowing my luck ill order one of these 'Metra installation kits' that I have seen and it wouldn't fit.
    I'd be extremely grateful if someone could point me towards anything that might be able to help in my search Even if its an old forum post that Ive missed asking the same question...
    Thanks for reading,
    Liam.
  2. Re: Double Din, headunit adapter/fascia kits?
    Oct 2005
    You need the centre console, radio cage, AC unit, ashtray and gear stick trim from a later model (00-02) - it's a big job but the parts are a direct fit.
    Depending on your budget, you might be better off getting a unit with a screen that pops out/flips up.
  3. Re: Double Din, headunit adapter/fascia kits?
    Dec 2008
    Dont throw away your old pre facelift surround....
    Depending on what radio you go for will depend on what surround you will require. I purchased a late A6 RNS-E for my A4 Avant but the only thing missing was the correct surround as it was of a slightly different size... and I couldn't find one anywhere!!
    Using a Silverline dremmel type tool, (only £20 from toolstation instead of £70 for a dremmel) I was able to grind down the old surround and ended up with two perfect strips to fill the holes the A6 unit didnt fit... I secured the surround with silicone sealant.
    Unless you knew the difference, you would not notice the re worked surround!
    If I had thrown the old one away, I would still be looking for a plastic filler!
  4. Re: Double Din, headunit adapter/fascia kits?
    Slamannan / central Scotland
    I would love to fit the double din as well but sadly my car doesnt have climate control so I dont think ive got the option.
    1997 A4 110 TDi Avant Quattro
    2002 Polo 6n2 1.4 TDi
  5. Re: Double Din, headunit adapter/fascia kits?
    Oct 2014
    Stevenage
    I was looking at doing a double din upgrade aswell found a couple of adapters on eBay but your looking at roughly 50-60 quid just for the plastic console there are really cheaper options on
    Original Audi A4 8E Double DIN Mounting Frame Mounts Bay A4 8E Recording | eBay
    Vrvws Audi A4 /s4 /rs4 Double Din Cage Genuine 8e0858005 Fits B6 B7 A4 | eBay
    http://www.caraudiocentre.co.uk/prod...04_p-28152.htm
    i have been looking to see if I can make the single din console into a double with a few alterations lol hope these websites help
  1. Aftermarket Double Din Headunit
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-01-2012, 08:15 PM
  2. JVC AVX820 Double Din Headunit For Sale
    By Stuart_B in forum In Car Entertainment
    Last Post: 14-03-2010, 05:37 PM
  3. Fitting A Double Din Headunit
    Last Post: 26-02-2010, 11:33 AM
  4. Double Din adapter
    By milroy in forum Audi A3 - Archive Topics
    Last Post: 27-09-2008, 09:28 PM
  5. Will a double din Headunit fit an 04 Passat?
    By kenny1001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-09-2008, 05:29 PM
