Thread: turbo cutting out on passat - loss of all power
  1. turbo cutting out on passat - loss of all power
    Nov 2008
    I have owned a vw passat ('03) for the last two years. from the day i bought it the turbo has been cutting out regularly, especially if the car is under a greater load ie going up hill, more weight / passengers. the problem is fixed if the car is turned off then on again. here is a list of things that i have done so far to remedy the problem:
    new turbo fitted, three different airflow meters fitted, boost pressure sensor changed, manifold pressure sensor replaced, replaced bottom pipe on inter-cooler (also noticed oil passing into the inter-cooler)
    the car has been seviced regularly: air filter, oil filter/oil change etc.
    for some reason fitting a tuning box helped reduce the frequency of the cut out, for reasons i don't understand.
    the last thing i tried was removing a pipe going into the egr valve. i drove the car for two miles to see if there was any difference and then replaced the pipe. since then the problem appears to have worsened. should i replace the egr valve???
    any help or advice would be great. i love the car bar this one very very very very annoying fault.
    best regards
    paul
  2. Re: turbo cutting out on passat!! loss of all power!!??!
    Jun 2007
    Gwent
    I have similar sounding symptoms with my '01 130 tdi, I have read the fault codes and mine is an overboost problem.
    From what I've been reading, this is usually caused by: (in no particular order) sticky turbo vanes (VNT mechanism), a problem with the VNT actuator, the boost control valve (N75) or a leak somewhere in the vacuum pipework to the N75/VNT actuator.
    I suggest you check the small vacuum pipe system back from the turbo, if no joy, then find somebody near you with vag com to scan it for a definite diagnosis?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: turbo cutting out on passat!! loss of all power!!??!
    May 2014
    Chelmsford
    First take the pipe off the n75 valve and make sure the pipe going to turbo actuator will hold a vaccume when you suck on it, sometimes the seals on the actuator go causing it to be open to atmosphere. If this is ok check the pipe from the vaccume pump on the end of the cam shaft. There is a small valve to keep pressure in the brake servo line. Take this valve off and ensure it is not blocked with carbon as this is quite common also. Hope this helps
  4. Re: turbo cutting out on passat - loss of all power
    Oct 2005
    Good advice albeit 6 years too late
  5. Re: turbo cutting out on passat - loss of all power
    May 2014
    Chelmsford
    Haha I see that after!!!!
  1. Loss of Power after Turbo (Overboost) Passat TDI 130 2002 B5.5
    By Mr Peter COYSH in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-09-2013, 07:15 AM
  2. Passat 2.0Tdi Sport B6 Turbo Power Loss? Judder cold start?
    By woody80uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-02-2012, 08:23 PM
  3. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  4. Please Help 2001 passat 20v turbo - loss of power
    By flashmatt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2008, 03:04 PM
  5. Power Loss 1.8 Turbo Passat
    By ANGELO33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-06-2007, 10:54 AM
