Thread: Passat electric window switch
  1. Passat electric window switch
    Sep 2007
    Does anyone know if you are able to change just one of the electric window switches or do you have'to change the whole 4 complete cos i've noticed on my 2001 Sport thatthe drivers switch only works on the full oppening mode it does'nt work on the first click that just moves the window down a bit at a time
  2. Re: Passat electric window switch
    134 Post(s)
    1995 Post(s)
    Not the switch, get a scan of the convenience system done but it is probably full of water. Have you had water getting into the car on the passengers side?
  3. Re: Passat electric window switch
    Jul 2007
    Bradford on Avon
    Had the same trouble as you Michelin, changed the switch on Sunday last.
    Its an easy job, took me about 30 mins and solved the problem!
  1. Electric Window Switch
    By HenryCrun in forum Beetle 2000-
    Last Post: 03-09-2007, 09:52 PM
  2. Golf Mk4 Electric Mirror switch
    By mydogsgotnonose in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2007, 11:23 AM
  3. Electric window mechanism jammed TDI sport Passat 52 plate
    By Tony31 in forum Chat - Anything with wheels
    Last Post: 29-04-2007, 10:43 PM
  4. Electric Mirror Control Switch
    By Rhostine in forum Passat - Archive Topics
    Last Post: 21-02-2007, 10:33 PM
  5. Passat Electric Window Problem
    By Brianm in forum Archive posts
    Last Post: 05-02-2007, 12:30 PM
