Thread: Throttle Actuator Control System...vcds
  1. Throttle Actuator Control System...vcds
    May 2014
    United Kingdom
    Hi folks new member here and dont know if i am in the right catergory for this, but a week ago while driving home my glowplug light started flashing on my dash on my audi a4 tdi {b8}model.having bought my ross-tec cable from ross tec and with the vcds software scanned the car and this fault showed up.. 9124 - Throttle Actuator Control System
    P2111 00 [232] - Stuck Open
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 127033 km
    Date: 2014.04.24
    Time: 18:59:27
    I have spent the morning taking off the throttle body and thoroughly cleaning it. It was fairly dirty and sooted up. Once clean and put back together I took the car a run hoping this would solve the problem but got half a mile along the road and fault light showed up again. Done rescan and same fault showing. Do I need a new throttle body or is there any thing else I could try. Would be really grateful for and suggestions.thanks..
  2. Re: Throttle Actuator Control System...vcds
    Southern County Softy
    20 Post(s)
    Clear the faulr and rescan.
    The date shows as an old fault.
    Can't find that fault code on the rosstech wiki.
    Sent from my GT-I9505 using Tapatalk
    A4 2.5 tdi QS (mapped)
  3. Re: Throttle Actuator Control System...vcds
    May 2014
    United Kingdom
    Sorry about that never copied scan to computer today that was the old scan i had at hand so just posted it..but i have done a scan and cleared the fault but like i said it keeps coming back dont want to buy a new throttle body if i can try something else first i was thinking there could be a sensor somewhere that might need cleaned..thanks for the reply..
  4. Re: Throttle Actuator Control System...vcds
    46 Post(s)
    Always search on here for your fault code - Fault code help
    Going by the OP of that thread, the throttle body needs cleaned.
  5. Re: Throttle Actuator Control System...vcds
    May 2014
    United Kingdom
    thanks for the reply but spent the whole morning cleaning the throttle body but still the fault comes back..am thinking the throttle body must be done,maybe i will just have to buy one..
  1. Question Throttle actuator. Control module performance
    By steve1950 in forum Golf MK5 - 2004 - 2009
    Last Post: 31-08-2013, 02:16 PM
  2. Throttle body actuator/DPF light
    By ianreay in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 10-07-2012, 08:52 PM
  3. A3 Throttle actuator
    By davej311 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-08-2011, 12:00 PM
  4. Throttle valve/actuator issue
    By staffop1 in forum VCDS - Help Requests
    Last Post: 01-12-2010, 11:57 PM
  5. throttle position actuator
    By selby2610 in forum VCDS - General Questions
    Last Post: 29-08-2008, 02:40 PM
