Thread: S3 - GFB DV+ issue
  1. S3 - GFB DV+ issue
    Oct 2013
    Worcestershire UK
    Hi all
    after much reading up on the GFB DV + I decided to get one installed to replace the original diverted valve.
    the main reason is because the car has had a stage 1 remap pushing more boost. It sounded like a good mod to have.
    since the fitting of the New DV+ I have noticed the lights on the dash for the RPD123456 etc are flashing white. The car is the s-tronic.
    car seems to drive ok but obviously can't see which gear I'm in?!
    the German car specialist who fitted the part has run the standard vag diagnostics and cleared the fault showing none but the gear indication lights are back flashing again?!
    any ideas or help please!?
    thanks in advance
  2. Re: S3 - GFB DV+ issue
    Dec 2012
    Brazil
    sounds pretty unrelated to be honest
  1. a6 oil sensor issue and airbag issue
    By 2400 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-12-2012, 11:26 AM
  2. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  3. First issue!!
    By Rosscow in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-08-2012, 09:16 PM
  4. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
