Thread: MMI update issue
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
  1. MMI update issue
    Apr 2014
    Congleton
    Hello all. I took the joy of picking up a 56 plate A6 2.7TDI Quattro this week. As I do a fair amount of miles I wanted to update the DVD NAV to latest database, and subsequently the MMI to 5570.
    I obtained genuine Audi UK discs for both, along with instructions on how to do the update.
    Upon starting the update, all was normal until it started to download. TUN/TUN/App was the first.
    It would complete about 13% then stop and say "Unlock Block 1, please wait" then it would start over, at 0% and go up to about 15%, then "Unlock Block 2, please wait" etc etc. Occasinally saying "waiting for device".
    Not knowing if this was normal or not, I waited around 1.5 hours, it had reach block 107 I think, but still not really any progress percentage wise.
    After a bit of research on the net I realised this wasn't normal and cancelled the download.
    The MMI rebooted but of course "NOT OK" was prevalent.
    I now don't have any radio, CD, or anything MMI audible related. The NAV works fine as I hadn't got to update it yet, but no voice commands.
    I've tried it at least another 3 times with the same result.
    I never get any error messages. After cancelling the download, the only error message present is that "the user terminated the download".
    Anybody have any idea as to why my car isn't taking the update?
    Audi want £117 to hook it up to a diagnostic machine, and I've heard horror stories of MMI unit failures costing upwards of £1600. :0(
    Kinda feels like I'm oy driving half a car right now!
    Thanks in advance for your knowledge!
    Hiflyer81
  2. Re: MMI update issue
    May 2007
    knee deep in clunge
    14 Post(s)
    oops you have a problem the radio is now wiped i suggest you firstly re try and secondly run a optical test to see what control unit you pooped, going to cost you this
  3. Re: MMI update issue
    Apr 2014
    Congleton
    Oh, well thanks for the 'technical' advice and revelling in my misfortune. Constructive comments would be welcome, thanks.
  4. Re: MMI update issue
    Oct 2005
    You were given constructive advice by one of the people who has probably forgotten more than we'll ever know.
    Have you done as he suggested? What was the outcome?
  5. Re: MMI update issue
    Apr 2014
    Congleton
    I tried the update originally about 4 times with the same outcome. I'm not a techy, I can cope with putting a CD in a CD changer, but I don't tinker with cars, so my knowledge is zero. What and how do I do an 'optical test'? I have no diagnostic equipment.
  6. Re: MMI update issue
    Nov 2009
    46 Post(s)
    You need VCDS or Audi to run it. If you look at the Map link in my forum signature there might be someone near you who could help.
  7. Re: MMI update issue
    Oct 2005
    Quote Originally Posted by hiflyer81 View Post
    So you've tried a few times and got the same result.
    On to the optical test, which as Chris says, needs VCDS (a diagnostic tool made by Ross Tech - Ross-Tech Store: VCDS) or a professional.
    As Chris also says, there's a map of users with VCDS - we don't know where you are because you've not completed the location section of your profile - but if you can see someone close to you, let us know and we'll point them to this thread. Most users will do this for beer money, some do it for nothing.
    If no one is close then you'll have to take it to an indy or Audi for the full tests but these will be chargeable
  8. Re: MMI update issue
    Apr 2014
    Congleton
    Thanks guys. From your link Chris, I've found an independent place near me that can do the diagnostics. I'll give them a call Monday and see what happens. I'll post back here the results for your interest.
    2 0 0
  9. Re: MMI update issue
    Apr 2014
    Congleton
    Whilst I'm waiting for tomorrow for the diagnostic, I wondered if it was a corrupted disc, so I copied the files across on to another disc, but with the same result.
    I took a few photos from during the update process, and also afterwards, when I'd cancelled the update and expanded the 'NOT OK' list to see what it said about it. Initially TUN was cancelled, it did the same with the DSP so I cancelled that too. I didn't let it get as far as the MMI.
    Update starts normally:
    Then the CD changer makes a noise around 17% each time and the message says:
    Another CD changer noise and it starts over:
    It carries on like this until cancelled.
    Once I cancelled all the updates, I rebooted the MMI and looked at the 'NOT OK' list:
    Going into the MMI 'NOT OK' list it says this:
  10. Re: MMI update issue
    Apr 2014
    Congleton
    Going into the TUN list:
    Then the DSP says this:
    Anybody seen this before?
    HiFlyer81
  1. MMI Update?
    By ronanmagee in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-03-2014, 11:28 PM
  2. Update on Fiscon Bluetooth issue MMI 2G High
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-08-2013, 03:09 PM
  3. Please Help mmi update
    By novasp in forum In Car Entertainment
    Last Post: 12-05-2012, 07:47 PM
  4. mmi update
    By Chris1965 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-04-2012, 01:42 PM
  5. MMI Update
    By SpinneyA6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-07-2009, 12:49 PM
