Thread: Timing chain jumped £££
  1. Timing chain jumped £££
    Feb 2010
    kirkcaldy scotland
    Hi everybody, I have read a lot of useful information from all the specialist members and I have a huge issue you can probably help guide me. The wife has a mk5 golf 1.6 fsi BLF and the timing has jumped and the car doesn't start, my local bosch garage did a compression test and got low compression in all cylinders and zero in cyl 4. He wanted to charge est £250 to remove the head and check for further damage. I don't want to spend too much on the car as its still on finance and anymore than £1k on repairs i'd be as well throwing it away.
    Any suggestions of what the damage could be, maybe some bent valves at best ??
    Thanks for your input in advance.
  2. Re: Timing chain jumped £££
    May 2008
    London, UK
    Common problem on the FSI/ TSI engines unfortunately and isn't really a cheap way of fixing. Your best bet might be to find a reconditioned/ used engine on eBay and getting someone to fit it. Take a read of this VW Mk5 Golf TSi Engine & Timing Chain Problem | Adam Lewin
  3. Re: Timing chain jumped £££
    Feb 2010
    kirkcaldy scotland
    Quote Originally Posted by J400uk View Post
    Thanks mate I read that article and sounds exactly the same issue, parked on a steep hill in gear and it rolled back jumping the chain.
    Hope everyone is aware, get your chain checked after 60-70k miles and don't park on hills in gear.
  4. Re: Timing chain jumped £££
    Colchester,Essex
    My mrss 1.2 Ibiza had chain jumped a few weeks ago too,it was only 1 tooth so a new kit with cam gears fitted and running well now but before spending any money see how much its jumped,time it up if not far off and check the compression,if all good fit a new kit,oil+filter.
  1. A6 3.2 Timing Chain!!
    By 06audia6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-08-2017, 09:06 AM
  2. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  3. Question Timing Belt or Timing Chain ??
    By thomascy in forum Golf MK5 - 2004 - 2009
    Last Post: 08-09-2009, 05:22 PM
  4. timing belt "jumped a tooth ?"
    By autotrans in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2008, 02:22 PM
  5. timing chain data for fitting new chain
    By stephen gal in forum Ibiza - Cordoba
    Last Post: 26-05-2008, 03:17 AM
