Thread: Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
Results 1 to 8 of 8
  1. Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
    Mar 2014
    Bulgaria
    The car misfires under load (cold and warm)
    Changed so far:
    Spark Plugs
    Ignition Coils
    MAF sensor
    Any Ideas ?
    AUDI A8 2004 4.2 petrol
  2. Re: Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
    Jan 2010
    United Kingdom
    The HT leads themselves might be worth a look as they can degrade with age...
  3. Re: Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
    Feb 2014
    West Sussex
    There are no ht leads with coil packs
    I have read that this can be a sign that the chain tensioner can be failing or the valve timing wheel has an elongated slot
    In both cases the replacement can be done with the engine in the car
    Audi TT Roadster S-Line Quattro in Daytona Grey
    New, shiny and still topless
  4. Re: Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
    Colchester,Essex
    Time it up to see if all good,only need to be slightly out to cause that.
  5. Re: Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
    Feb 2014
    West Sussex
    It is chain driven - can't time it up - those parts may need to be swapped out
  6. Re: Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
    Colchester,Essex
    You can time it up,just look up.I had a corsa with 1 cam 10 degree out and running rough at idle.
  7. Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
    Feb 2014
    West Sussex
    If the timing is out it would mean the sprocket is worn or the chain has jumped teeth
    The first can be done in the car but the latter is an engine out job
    Corsa with a cam belt is a different beast to a v8 with chain drive which if I recall consist of 4 independent chains and a bunch of guides and tensioners
  8. Re: Misfire on cylinder 5; 6; 7; 8 on A8 4.2 petrol 2004
    Mar 2014
    Bulgaria
    FYI
    It was the cam tensioner
  1. A3 Cylinder 2 Misfire
    By Bannonn in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-07-2013, 08:18 PM
  2. Cylinder 2 Misfire
    By s-l-i-x in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-05-2009, 08:34 PM
  3. Cylinder Misfire help
    By Elwood686 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-09-2008, 07:00 PM
  4. Please Help Misfire on Cylinder 1
    By Pudz in forum Polo - Derby - Lupo - Fox
    Last Post: 31-05-2008, 03:46 PM
  5. Misfire in cylinder 3!!
    By jenson in forum Bora - 1998 - 2005
    Last Post: 23-08-2006, 06:23 PM
