Thread: Memoscan VAG5053 - any experience of applying VCDS tweaks?
  1. Memoscan VAG5053 - any experience of applying VCDS tweaks?
    Apr 2014
    Ipswich, UK
    Hi all,
    Maybe a stupid question, but I'd thought I'd put it out there - I have a Memoscan VAG5053 that I bought some time ago as a fault code reader for my Passat. It seems to have some rudimentary support for applying adaptions - does anyone have any experience of using one of these devices to apply A6 VCDS tweaks (I'm guessing the primary difference vs VCDS is usability, and perhaps the need to be able to do binary->hexdecimal conversions yourself - very carefully of course!)
    2012 Powerful tool MemoScan VAG5053 VW AUDI Scanner Service Reset: Amazon.co.uk: Electronics
    If not, I'll give it a try myself and report back on feasibility/difficulty factor sometime in the next week.
    Thanks,
    Alan
    2014 Audi A6 3.0 TDI (245 PS) quattro S-Line (C7)
  2. Re: Memoscan VAG5053 - any experience of applying VCDS tweaks?
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Most of the changes in the tweaks thread are coding changes rather than adaptation changes. Is the tool you have capable of this?
    A lot of the car's modules have a "Long Coding Helper" option in VCDS which makes amending the coding very simple indeed. If you look at the underlying coding string (in Hex) it's a little more scary, though. I would approach making manual changes to that with huge care and trepidation! If you do want to experiment and you need to see how a hex coding string breaks down in Long Coding Helper, ask away
    Good luck!!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  1. Question VCDS tweaks
    By k6rff in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 25-02-2016, 12:35 PM
  2. Vagcom tweaks for 2014 CC??
    By mkenn in forum Passat CC
    Last Post: 28-08-2014, 08:30 PM
  3. VCDS Lite cable experience - Audi A4 B6 (Dec 2001, 1.9tdi 130 AWX)
    By wutr in forum VCDS - General Questions
    Last Post: 12-03-2013, 09:13 PM
  4. vagcom tweaks
    By leeocallaghan in forum VCDS - Help Requests
    Last Post: 26-02-2013, 09:44 AM
  5. Memoscan VAG 5053 & New Beetle fault
    By tezbot58 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 09-01-2009, 11:26 AM
