Thread: Oil Pressure Switch 2.5tdi (AFB)
  1. Oil Pressure Switch 2.5tdi (AFB)
    Jul 2007
    Hi everyone, can anyone guide me to where the Oil Pressure Switch is for the A6 2.5 tdi (1999) AFB engine? I have a bad oil leak just behind the alternator, and think that this may be the oil pressure switch. Thanks.
  2. Re: Oil Pressure Switch 2.5tdi (AFB)
    If you follow the pipe from the output at the bottom of the filter bracket, that pipe goes to a casting into which an oil pressure switch and and oil temp sensor are mounted. If you email me I send you the drawing. info@3DAssociates.co.uk Regards Peter
  3. Re: Oil Pressure Switch 2.5tdi (AFB)
    Jul 2007
    Hi Peter, I have just sent you an email - please pass on the drawings. I'm not sure if this is anywhere the alternator side of the engine though? I'll check it out when I know where to look. Thanks.
  1. T4 2.5TDi boost pressure - what should it be?
    By DubDick in forum The Commercial Range
    Last Post: 04-09-2007, 12:26 PM
  2. ac pressure switch.1.9 gt tdi golf
    By stuffs in forum Golf MK4 - 1999 - 2004
    Last Post: 12-07-2007, 03:57 PM
  3. Oil Pressure Switch
    By e6m6a6 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-06-2007, 05:42 PM
  4. S4 Oil Pressure?
    By SnakeEyes in forum Archive posts
    Last Post: 30-03-2007, 06:28 AM
  5. Golf V5 oil pressure switch location???
    By neil b in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2007, 05:40 PM
