Thread: Clutch fitting
  1. Clutch fitting
    Dec 2007
    Belfast
    Hi All.
    I am wondering how a mechanic decides the biting point of a clutch when a new one is being fitted ?
    Marko.
  2. Re: Clutch fitting
    Pembrokeshire
    22 Post(s)
    normally we don't, they tend to be self adjusting so the biting point is set for you. on a cable clutch with an adjuster, you set it up sort of halfwayish, then test drive it and make sure all the gears can select nicely. quite often the biting point will be in a manual, clutch pedal height from floor, but this info is not always to hand so you just use experience.
  3. Re: Clutch fitting
    Dec 2007
    Belfast
    Thanks Zollaf.
    I'm thinking my clutch is getting a wee bit tired. With the pedal fully depressed, and on letting the pedal out, the bite is almost the full travel of the pedal. It was a motor factors clutch which I read somewhere aren't amongst the greatest. Not sure if mine is the cable type. It's going onto an AZD 2001.
  4. Re: Clutch fitting
    Pembrokeshire
    22 Post(s)
    high biting point is a sure sign of a worn clutch plate.
  5. Re: Clutch fitting
    Dec 2007
    Belfast
    So a trip to the local garage is in order ?
  6. Re: Clutch fitting
    Pembrokeshire
    22 Post(s)
    4th gear, low revs, 2k rpm or so, floor it. does it slip. slight dab on the pedal throttle flat out to get it slipping, foot straight off clutch, does it grab and revs fall straight back down or do revs slowly come down ?
  7. Re: Clutch fitting
    Dec 2007
    Belfast
    I will try that tomorrow. Will update.
  8. Re: Clutch fitting
    Dec 2007
    Belfast
    Hi Zollaf.
    The clutch isn't slipping. Going to get her done hopefully this week for piece of mind, and while I have the money.
    Thanks for your input.
    Marko
  1. Fitting new clutch 1.8se help
    By Duncstar in forum Golf MK3 - 1993 - 1999
    Last Post: 09-06-2009, 10:54 AM
  2. Cost of new clutch/DMF fitting??
    By gbrad2x in forum Bora - 1998 - 2005
    Last Post: 17-12-2008, 01:23 PM
  3. Unusual ticking noise after fitting new clutch :(
    By AL1210 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-07-2008, 09:59 PM
  4. Please Help Unusual ticking noise after fitting new clutch :(
    By AL1210 in forum New Member Introductions
    Last Post: 28-06-2008, 01:32 AM
  5. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
