Thread: Headlight Washers?
Results 1 to 9 of 9
  1. Headlight Washers?
    Aug 2007
    My A6 appears to have the washers for the headlights but where is the control to use them?! Can't find it anywhere and I don't have a manual with the car!! Cheers!
  2. Re: Headlight Washers?
    Aug 2007
    Wiltshire, UK
    Do they work when the lights are switched on and you wash your windscreen ?
  3. Re: Headlight Washers?
    Aug 2007
    I'll try that tomorrow! Not driven it in the dark yet!
  4. Re: Headlight Washers?
    Aug 2007
    Didn't work....presumably knackered then?!
  5. Re: Headlight Washers?
    Aug 2007
    Newport, Wales
    7 Post(s)
    Do you have Xenon headlights?
    If you don't your car probably won't have them unless the "Winter Pack" was specified as an option when the car was new.
    I don't know if A6's without the headlight washers just have a blanker or if there should be no hole at all - anybody?
    -Alex.
  6. Re: Headlight Washers?
    Aug 2007
    Looking under the bonnet it appears to have all the appropriate bits there, just no switch. No idea on the xenon bit.
  7. Re: Headlight Washers?
    Jul 2007
    My 2002 Audi A6 Avant doesn't have them and doesn't have the blanking plates - just a standard bumper.
    Check the fuses as if nothing is happening at all then this could be the most likely (and cheapest) cause!
    The fuses are on either the driver or passenger side of the console - open the door and you'll see you can remove the appropriate side of the console.
    Rob
  8. Re: Headlight Washers?
    Aug 2007
    Will take a look, thanks!
  9. Re: Headlight Washers?
    Sep 2007
    There is no switch for them they work when the lights are on and you wash wipe the winscreen for a few seconds. They pop up and squirt water on the lights. The pump under the lights gives up and are expensive to replace so are often blanked off.
    I have seen manuals on e-bay.
  1. Polo Headlight
    By hussaingio in forum Polo - Derby - Lupo - Fox
    Last Post: 22-03-2009, 05:19 PM
  2. 1998 A6 Headlight Washers
    By KiwiA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-06-2007, 06:36 AM
  3. poor headlight a6
    By seahunter in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-04-2007, 05:17 PM
  4. Headlight Condensation
    By redmax90 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-02-2007, 12:24 AM
  5. A4 Headlight
    By andrew00011 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-01-2007, 07:52 AM
