Thread: VCDS Scan results
Results 1 to 10 of 10
Threaded View
  1. VCDS Scan results
    Sep 2010
    teesside england
    Hello Guys.
    I've had an Airbag warning lamp on for a while and I just had a lend of a mate's VCDS and I've ran a scan.
    Here's the results....
    Code:
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine        Labels: 03G-906-016-BKD.lbl
       Part No SW: 03G 906 021 KK    HW: 03G 906 021 KK
       Component: R4 2,0L EDC  000SG  9970
       Revision: --H03---    Serial number: VWZ7Z0F3688062
       Coding: 0000072
       Shop #: WSC 00784 210 86038
       VCID: 72E1AB6C6DB43EE
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
       Component: ESP FRONT MK60      0102
       Revision: 00H13001
       Coding: 0023170
       Shop #: WSC 00046 412 00000
       VCID: 71E3A46068B2056
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 DP
       Component: Climatic PQ35   090 0505
       Shop #: WSC 00000 000 00000
       VCID: 75EB90701CDA296
    1 Fault Found:
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000003956295
       Coding: E5890F2700041800001400001400000000087F075C
       Shop #: WSC 00046 412 65536
       VCID: 2B5F76088A1E2F6
       Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  013  0402
       Coding: 00063445
       Shop #: WSC 00046
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 00046
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
       Component: 38 AIRBAG VW8   018 2200
       Revision: 02018000    Serial number: 0038MD0A8HYT
       Coding: 0013112
       VCID: 3B7F46487A7EBF6
    1 Fault Found:
    01218 - Side Airbag Igniter; Passenger Side (N200)
                001 - Upper Limit Exceeded - Intermittent - MIL ON
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 034 0070
       Coding: 0000012
       Shop #: WSC 00046 412 442368
       VCID: 76E9977C01DC22E
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 962 G
       Component: KOMBIINSTRUMENT VDD 4312
       Coding: 0003403
       VCID: 2F676218BE06536
    Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 280010630887F1
       Coding: 3D0F0B40070001
       Shop #: WSC 00046 412 32768
       VCID: 2A51730C85E436E
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO            VDD 4312
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2314
       Coding: 0000564
       VCID: 3669577C415C62E
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K2 909 144 K
       Component: EPS_ZFLS Kl.5   D06 1701
       VCID: 346D6D74572070E
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AJ
       Component:    KSG              0401
       Coding: 01C802087F2D8405485AC69010CC
       VCID: 78F599440BC854E
       Component:   Sounder No Answer
       Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Part No: 1K0 951 177 A
       Component: Innenraumueberw.005 0202
    2 Faults Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
                000 -  -
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
       Part No: 1K0 959 702 K
       Coding: 0000564
       VCID: 37775A7846569B6
    1 Fault Found:
    00110 - Right Mirror Turn Signal Lamp (L132)
                012 - Electrical Fault in Circuit
    Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
       Part No SW: 1K0 035 186 P    HW: 1K0 035 186 P
       Component: Radio FO3       013 0014
       Revision: 00013000    Serial number: VWZ7Z2F0158674
       Coding: 0040400
       VCID: 336F6E68522E776
    Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
       Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
       Component: PTC-Element         0404
       Revision: 00800000    Serial number:
       VCID: 2D5B7810B40A216
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
                014 - Defective
    As you can see the scan brought up a few other faults.
    1. Climatic.
    1 Fault Found:
    Could this be sorted by re-gassing?
    2. Alarm horn.
    2 Faults Found:
    000 - -
    I can remember the alarm going off a few times for no reason about a year ago.
    3. Wing mirror repeater.
    1 Fault Found:
    Could this be sorted with a new bulb?
    4. Auxiliary heater.
    1 Fault Found:
    014 - Defective
    Any Ideas???
    The air bag warning lamp has cleared. I'll see how long that stays off.
    Thanks for any help.
  1. results of scan :(
    By Mark Shuker in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-01-2014, 06:16 PM
  2. Passat B6 2.0 Tdi Limp Mode problem - Full VCDS scan results included
    By slingshot1801 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-04-2013, 12:00 PM
  3. Full scan results
    By PETER G in forum VCDS - Help Requests
    Last Post: 01-01-2012, 06:04 PM
  4. Audi A6 VagCom Scan Results.
    By cwilding in forum VCDS - Help Requests
    Last Post: 19-11-2010, 10:19 PM
  5. Scan Results
    By kite in forum VCDS - General Questions
    Last Post: 18-03-2009, 07:54 PM
