Thread: Advice regarding AC N280 Valve, no cold air
  1. Advice regarding AC N280 Valve, no cold air
    warp_speed Guest
    I've got a 2.0TFSI 2007 A4 with a Denso AC compressor.
    AC stopped blowing cold air, had the system recharged 2 years ago so I ran a VCDS check and it came back with compressor regulator valve (N280) intermittent fault. ECON light goes off when pressed and AC pressure looks ok/within spec.
    1. Can the N280 valve be replaced without replacing the whole compressor, Audi said no and whole compressor needs replaced at £650 excl VAT for compressor, needless to say I'm looking for alternatives.
    2. Spoke with Aircon refurbishment guy who said that even changing the valve theres a strong chance of pulley will have sheered the aircon shaft and new compressor is needed and there is no way of checking. Does this sound right?
    would appreciate any help people can provide to this.
  2. Re: Advice regarding AC N280 Valve, no cold air
    warp_speed Guest
    problem resolved, turns out wiring connector was disconnected from valve, unsure if they do this during a service at Audi, don't think so some how and unsure in how it unclipped itself and worked its way loose. But happy none the less :-)
  1. Replies: 1
    Last Post: 03-09-2013, 12:54 PM
  2. Please Help Audi a4 tdi v6 180bhp b6 Valve Stuck Open Maybe? air coming back through air box
    By lewissykes81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2013, 11:00 AM
  3. Replies: 0
    Last Post: 08-07-2011, 04:48 PM
  4. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  5. Heaters Blowing Cold air! Head gasket or Heater Valve?
    By yellow-160 in forum Golf MK2 - 1984 - 1992
    Last Post: 08-06-2008, 04:29 PM
