Thread: tdi 90 running cool
Results 1 to 10 of 11
  1. tdi 90 running cool
    Apr 2014
    Recently bought a vw vento 1.9 tdi 90bhp the pre pd engine, now it runs very cool can get it up to 80degree if I'm sat in traffic for around 30mins+ but soon as I start moving again temp drops down to 70 or even lower some times.
    So what could cause it? I'm thinking thermostat stuck open maybe?
    We're is the thermostat on these engines?
    Help welcome
  2. Re: tdi 90 running cool
    46 Post(s)
    Probably thermostat. Buy genuine or OE spec if you can.
    Welcome.
  3. Re: tdi 90 running cool
    Apr 2014
    We're abouts is the thermostat on the engine? Is it on the cylinder head were the top rad pipe meets the engine?
  4. Re: tdi 90 running cool
    46 Post(s)
    I have no idea I'm afraid, sorry.
  5. Re: tdi 90 running cool
    Oct 2005
    What is the engine code?
  6. Re: tdi 90 running cool
    Apr 2014
    I don't no tbh how can I find that out?
  7. Re: tdi 90 running cool
    Oct 2005
    Look on top of the timing belt cover or on a sticker in the boot/spare tyre well.
    It's a late model Vento (1997/8?) and as you've said it's a TDI 90 it's only going to either a 1Z or an AHU.
    On a 1Z (and possibly an AHU) the thermostat is on the right side of the engine - here a photo (not mine) which should help photo found on the internets it's number 12 in the image.
    The housing gets brittle over time too and often breaks when trying to remove it, make sure your friendly local stockist has a spare in stock before you start work.
    Good luck
  8. Re: tdi 90 running cool
    Apr 2014
    That's great thanks I will check see if I can get the housing and thermostat from vw then
    Thanks for help
    Will update when I've done it see if it cures the issue
  9. Re: tdi 90 running cool
    Apr 2014
    Fitted thermostat today now gets up 90 and stays there with out issue
    Thanks for help guys
  10. Re: tdi 90 running cool
    Oct 2005
    Good news - how was the housing?
  1. audi a6 tdi running cool
    By howardwalsh in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-03-2009, 09:49 PM
  2. A6 heating running cool
    By gazza57 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-03-2009, 02:47 PM
  3. 2.5 engine running cool
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-03-2009, 11:33 PM
  4. a4 1.9 tdi pd running cool
    By sbt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-07-2008, 10:15 PM
  5. 80 TDi running cool?
    By Overdose in forum 80 - 90
    Last Post: 09-01-2008, 09:16 PM
