Thread: A/C pressure/temp sensor location
  1. A/C pressure/temp sensor location
    Dec 2010
    CD UK
    6 Post(s)
    I've just had no reaction from my A/C and the red LED on the button itself went out within a couple of seconds of pressing it. VCDS told me it was an intermittent fault on the A/C pressure/temp sensor.
    Given that I've just given it a good wash prior to tomorrow's MOT - and paid special attention to the wheel arches of my allroad; could water ingress be the culprit. i.e. is that the location of the sensor?
    To top it all, my warranty runs out in 2 days and the nearest dealer is 50 miles away (assuming they could diagnose and rectify in that timescale). Can anyone advise the approx parts price and job time. I need to weigh this up against my warranty excess...
    Thanks for any advice.
  2. Re: A/C pressure/temp sensor location
    Nov 2009
    46 Post(s)
    And the fault code is?
  3. Re: A/C pressure/temp sensor location
    Dec 2010
    CD UK
    6 Post(s)
    00256 for the sensor (G395)
    02071 for the databus
  4. Re: A/C pressure/temp sensor location
    Nov 2009
    46 Post(s)
    Can you post the autoscan for the two affected modules.
  5. Re: A/C pressure/temp sensor location
    Dec 2010
    CD UK
    6 Post(s)
    Sorry. Wasn't trying to be awkward, but VCDS laptop is in the middle of a humungus Windows update at dial-up speeds.
    This is what I got when I checked for fault codes on the HVAC earlier:
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Control Module Part Number: 4F0 910 043 B HW: 4F2 820 043 AA
    Component and/or Version: KLIMABETAETIGUNGH30 0080
    Software Coding: 0001302
    Work Shop Code: WSC 02325 785 00200
    VCID: 1D3AA22CC47DCFF6901-8048
    2 Faults Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 62740 km
    Time Indication: 0
    Date: 2014.04.13
    Time: 18:16:58
    02071 - Local Databus
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 218
    Mileage: 62623 km
    Time Indication: 0
    Date: 2014.04.07
    Time: 13:15:55
    If you need a full Auto Scan I can do that tomorrow morning.
  6. Re: A/C pressure/temp sensor location
    Dec 2010
    CD UK
    6 Post(s)
    At a snail-like 244k my Windows update took forever, but here's the complete auto-scan after my successful MOT:
    Monday,14,April,2014,12:18:36:52225
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WAUZZZ4F59Nxxxxxx License Plate: XXX XXX
    Mileage: 38998 Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 34 42 46 4F 52 53 56 5F 62
    69 72 76
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (CDY) Labels: Redir Fail!
    Part No SW: 4F9 910 402 A HW: 4F0 907 401 E
    Component: 3.0TDI EDC17G004AG 0080
    Revision: 16H01--- Serial number:
    Coding: 0125002C190F0928
    Shop #: WSC 00590 210 61861
    VCID: 244C97C8E717FE3EDFF-FFFF
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 R HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0020
    Revision: --H04--- Serial number: 4516603
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 346C678857F76EBE4FF-8061
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AM HW: 4F0 614 517 BD
    Component: ESP8 quattro H01 0100
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0000396
    VCID: 6FE6A8E47E510D6672D-803A
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
    Component: FBSAUDIC6 ELV H05 0100
    Revision: 00H05000 Serial number: 10602601299800
    Coding: 0000147
    Shop #: WSC 02324 785 00200
    VCID: 254A8ACCEC2D0736C81-8070
    Subsystem 1 - Part No: 4F0 910 132 E
    Component: FBSAUDIC6 EZS H03 0020
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
    Component: KLIMABETAETIGUNGH30 0080
    Revision: 00000074 Serial number: 00000030433982
    Coding: 0001302
    2 Faults Found:
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 220
    Mileage: 62743 km
    Time Indication: 0
    Date: 2014.04.14
    Time: 09:13:23
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 218
    Mileage: 62623 km
    Time Indication: 0
    Date: 2014.04.07
    Time: 13:15:55
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 N HW: 4F0 907 279
    Component: ILM Fahrer H22 0320
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0017121
    Shop #: WSC 02335 785 00200
    Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H10 0040
    Coding: 00056595
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
    Component: CDC-MP3-Pana H47 0050
    Revision: 00000012
    VCID: 21429EDC3805EB16B49-8074
    Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
    Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003CH004DJ5U
    Coding: 30314236303630303033554A305234463053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 30646B986BEF529E2B7-8065
    Crash sensor for side airbag; driver side:
    Serial number: 3574SRB400008D2099FG
    Crash sensor for side airbag; passenger side:
    Serial number: 3584SRB400008D50E8AJ
    Crash sensor for side airbag; rear driver side:
    Serial number: 35152RB402F85LSJ6460
    Crash sensor for side airbag; rear passenger side:
    Serial number: 35252RB402B85LSJ34H5
    Crash sensor for front airbag; driver side:
    Serial number: 3554NRB400004B307D3.
    Crash sensor for front airbag; passenger side:
    Serial number: 3564NRB400004B4BFD8K
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0530
    Revision: 00H05000 Serial number: 90055090830399
    Coding: 0102142
    VCID: 275680C496211526FAD-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 K HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0025
    Revision: 4LA80024 Serial number: 2400L094018119
    Coding: 000303
    Shop #: WSC 02391 823 56573
    VCID: 37765084868185A66AD-8062
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0107
    Address 34: Level Control Labels: None
    Part No SW: 4F0 910 553 D HW: 4F0 907 553 A
    Component: J197 LUFTFEDER H17 0030
    Serial number: 00872000300600
    Coding: 0000220
    Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
    Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000100927247
    Coding: 011F06204041410003
    VCID: 46882D40F16BEC2EE1B-8013
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H27 0220
    Revision: 02200027 Serial number: 01177622070000
    Coding: 0402171
    VCID: 31626E9CA8E55B96249-8064
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H13 0100
    Revision: Serial number: 00000000625651
    Coding: 0001113
    VCID: DEB8652009FB14EE49B-808B
    Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
    Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000100932083
    VCID: 458A2A4CCC6DE736E81-8010
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
    Component: EPB CEFC0090 H05 0090
    Revision: --H05---
    Coding: 0000321
    Shop #: WSC 02145 785 00200
    VCID: 21429EDCF805EB16B49-8074
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 056 B HW: 4F0 035 056
    Component: Radio U STD H45 0020
    Revision: AB001007 Serial number: 342DQ097593311
    Coding: 010003020100000000
    VCID: 1F4698240E71DDE682D-804A
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 652 A HW: 4E0 035 652
    Component: B-BN-EU H51 0048
    Revision: -------- Serial number: 349D-097510694
    Coding: 010101050002D3ED01002305EF6300030001
    Shop #: WSC 00590 210 88776
    Subsystem 1 - Part No: 4G0 919 884 A
    Component: EUROPE 2008 5608
    Subsystem 2 - Part No SW: 4L0 919 604 HW: 4L0 919 604
    Component: DU6 Basic H43 0306
    Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
    Component: Bedienteil MM H01 0060
    1 Fault Found:
    00658 - Control Head
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 61560 km
    Time Indication: 0
    Date: 2014.03.22
    Time: 15:16:43
    Freeze Frame:
    Voltage: 12.40 V
    Bin. Bits: 001
    Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
    Component: TSG HL H10 0251
    Revision: Serial number: 0000100936691
    Coding: 010E04204041220003
    VCID: 438E3454C259D906C65-8016
    Address 69: Trailer (J345) Labels: 4F0-907-383.clb
    Part No SW: 4F0 907 383 D HW: 4F0 907 383 D
    Component: Anhaenger H08 0080
    Revision: 2B002002 Serial number: 00000117584839
    Coding: 0103030000000000
    VCID: 2C5C7FE84FC7367E17F-8079
    Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
    Component: TSG HR H10 0251
    Revision: Serial number: 0000100934724
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 B HW: 4L0 919 283 B
    Component: Parkhilfe 4-Kan H02 0500
    Revision: 00H02000 Serial number: 12330910003142
    Coding: 0011416
    VCID: 295286FC80352356EC9-807C
  7. Re: A/C pressure/temp sensor location
    Dec 2010
    CD UK
    6 Post(s)
    Chris. Any thoughts on this?
    Thanks.
  8. Re: A/C pressure/temp sensor location
    Sep 2011
    Lurking over a keyboard ...
    The pressure sensor is located on RHS of rad/evaporator when facing car from front. Fellow members have done this DIY, do a search of forum and you will find info, I would link threads but at mo on a fruit tech equipment and touch screen really isn't my my forte! + the combo of grape juice not help my human motor skills! LOL
    I would check contacts on plug to sensor before replacing.
    ATB
    G
  1. Please Help Temp Sensor location
    By chrismac in forum Golf MK5 - 2004 - 2009
    Last Post: 12-02-2012, 09:31 PM
  2. Question 1.9 tdi AFN engine, oil pressure/temp switch location
    By 1969ghia in forum Touran - Sharan - Caravelle
    Last Post: 31-05-2010, 02:52 PM
  3. Coolant Temp sensor location
    By Saturn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-12-2009, 07:41 PM
  4. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
  5. Please Help A3 G81 Temp Sensor Location
    By onzarob in forum Audi A3 - Archive Topics
    Last Post: 19-09-2008, 10:17 AM
