Thread: VCDS scan today, what does it all mean?
  1. VCDS scan today, what does it all mean?
    Jan 2024
    Corsham
    Code:
    Thursday,29,February,2024,13:38:48:06808
    VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
    Data version: 20231027 DS351.0
    Ross-Tech: Home
    VIN: WAUZZZ4F78N040846   License Plate: GV57
    Mileage: 186130km-115655mi   Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62
              72
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: Malfunction 0010
    Address 01: Engine        Labels: 059-907-401-BPP.clb
       Part No SW: 4F5 910 401 K    HW: 4F0 907 401 C
       Component: 2.7L V6TDI  G000SG  0010
       Revision: --H04---    Serial number:
       Coding: 0011322
       Shop #: WSC 02335 758 00200
       VCID: 290EFA5265F88BC258D-807C
       VINID: 9D196AAAA1161C87801002041818133C51
    2 Faults Found:
    053255 - Please check Fault Memory in Battery Monitoring Module
                   U1007 - 001 -
                 Freeze Frame:
                        Fault Status: 01110001
                        Fault Priority: 0
                        Fault Frequency: 3
                        Reset counter: 255
                        Mileage: 185211 km
                        Time Indication: 0
                        Date: 2024.01.31
                        Time: 14:32:42
                 Freeze Frame:
                        RPM: 756 /min
                        Torque: 31.2 Nm
                        Speed: 0.0 km/h
                        (no units): 1224.0
                        Voltage: 14.14 V
                        Temperature: 9.0C
                        (no units): 4.0
    008200 - Intake Manifold Flap; Bank 1
                   P2008 - 002 - Electrical Malfunction - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 0
                        Fault Frequency: 15
                        Reset counter: 255
                        Mileage: 185214 km
                        Time Indication: 0
                        Date: 2024.02.01
                        Time: 09:47:52
                 Freeze Frame:
                        RPM: 126 /min
                        Torque: 261.3 Nm
                        Speed: 0.0 km/h
                        Voltage: 10.03 V
                        Duty Cycle: 7.9 %
                        Duty Cycle: 41.0 %
                        Duty Cycle: 80.9 %
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
       Component: ESP8 front      H01 0070
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0020871
       VCID: 6596B66249606FA2BC5-8030
    No fault code found.
    Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0230
       Revision: 09010701    Serial number: 10601500854927
       Coding: 0000145
       Shop #: WSC 00116 210 91014
       VCID: 6392A87A47541192521-8036
       Subsystem 1 - Part No: 4F0 910 131 D
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head        Labels: Redir Fail!
       Part No SW: 4F0 910 769 G    HW: 4F0 035 769 A
       Component: MMI Cockpit     H35 0410
       Revision: C61060DE    Serial number: AUZ6Z3G8CG4391
       Coding: 0540002
       VCID: 313E12324D28F30290D-8064
       Subsystem 1 - Part No: 4F0 910 609 E
       Component: Bedienteil MMIC6H02 0060
       Subsystem 2 - Serial number: 00000000838107
       Subsystem 3 - Serial number: 0116.08.070000000100010122
       Subsystem 4 - Serial number: 010122
    3 Faults Found:
    00384 - Optical Databus
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 0
    01317 - Control Module in Instrument Cluster (J285)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 255
                        Time Indication: 0
                 Freeze Frame:
                        Bin. Bits:  0000010
    02095 - Component Protection Active
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 0
    Address 08: Auto HVAC        Labels: 4F0-910-043.clb
       Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000052    Serial number: 00000030272523
       Coding: 0001302
       VCID: 1C60D3863AAA6E6AD3B-8048
    1 Fault Found:
    00657 - Positioning Motor for Central Vents (V102)
                003 - Mechanical Failure - Intermittent
                 Freeze Frame:
                        Fault Status: 00100011
                        Fault Priority: 3
                        Fault Frequency: 12
                        Reset counter: 31
                        Mileage: 185381 km
                        Time Indication: 0
                        Date: 2024.02.06
                        Time: 16:29:43
                 Freeze Frame:
                        Voltage: 13.00 V
                        Temperature: 22.0C
                        (no units): 42.0
                        (no units): 32.0
                        Temperature: 12.0C
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H18 0250
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0000101
       Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0190
       Coding: 00064784
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0100
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1        Labels: Redir Fail!
       Coding: 0540002
    Address 15: Airbags        Labels: 4F0-910-655-8R.clb
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0TKUPJ
       Coding: 0013381
       Shop #: WSC 02325 758 00200
       Subsystem 1 - Serial number: 6332CSME16222132N
       Subsystem 2 - Serial number: 6342CSME19273B465
       Subsystem 3 - Serial number: 6352QSME36770F2DU
       Subsystem 4 - Serial number: 6362QSME385A4A05N
       Subsystem 5 - Serial number: 63734SME36064849+
       Subsystem 6 - Serial number: 63834SME35521313P
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Component: J0527               0410
       Revision: 00H02000    Serial number: 90054072060202
       Coding: 0102042
       VCID: 270AFC6A73ECBDB24E9-8072
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H02 0030
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 900 C    HW: 4F0 920 951
       Component: KOMBIINSTR. M73 H16 0240
       Revision: 00200000    Serial number: 64711FM87
       Coding: 3332458
       Shop #: WSC 00011 888 06946
       VCID: 2018E77616C24A8A0F3-8074
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0060
       Revision: 00H06000    Serial number: 1100B0750483EE
       Coding: E5519E5330020600
       VCID: 2D060E42511097E2B45-8078
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 20
                        Mileage: 185248 km
                        Time Indication: 0
                        Date: 2024.02.03
                        Time: 13:33:31
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
       Component: TSG FA          H12 0210
       Revision: 00000000    Serial number: Vt˜
       Coding: 0003610
       Shop #: WSC 02327 758 00200
       VCID: 2C0003466A0A9EEAA3B-8078
    1 Fault Found:
    02123 - Door Warning Light / Entry Light
                012 - Electrical Fault in Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 26
                        Mileage: 185374 km
                        Time Indication: 0
                        Date: 2024.02.06
                        Time: 12:21:14
    Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H25 0200
       Revision: 02000025    Serial number: 01059725790000
       Coding: 0000763
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    8 Faults Found:
    01701 - Dimmer for Interior Lighting
                007 - Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00100111
                        Fault Priority: 3
                        Fault Frequency: 40
                        Reset counter: 24
                        Mileage: 185256 km
                        Time Indication: 0
                        Date: 2024.02.04
                        Time: 09:39:26
    02396 - Parking Light Rear Left (M4)
                009 - Open or Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00101001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 25
                        Mileage: 185374 km
                        Time Indication: 0
                        Date: 2024.02.06
                        Time: 15:03:32
    02736 - Bulb for Tail/Fog Light; Left
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 25
                        Mileage: 185374 km
                        Time Indication: 0
                        Date: 2024.02.06
                        Time: 15:03:32
    01518 - Bulb for Back-Up Lights; Left (M16)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 32
                        Mileage: 185374 km
                        Time Indication: 0
                        Date: 2024.02.06
                        Time: 15:03:32
    02397 - Parking Light Rear Right (M2)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 32
                        Mileage: 185522 km
                        Time Indication: 0
                        Date: 2024.02.16
                        Time: 07:37:22
    01504 - Bulb for License-Plate Light (X)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 30
                        Mileage: 185522 km
                        Time Indication: 0
                        Date: 2024.02.16
                        Time: 07:37:28
    02737 - Bulb for Tail/Fog Light; Right
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 30
                        Mileage: 185522 km
                        Time Indication: 0
                        Date: 2024.02.16
                        Time: 07:38:40
    01519 - Bulb for Back-Up Lights; Right (M17)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 31
                        Mileage: 185522 km
                        Time Indication: 0
                        Date: 2024.02.16
                        Time: 07:40:36
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 910 223 K    HW: 4F0 035 223 L
       Component: Amp.-ASK-RD   H07 0250
       Revision: S0900000
       Coding: 010001
       Shop #: WSC 02399 823 56573
       VCID: 2614F16E78E6A4BA75F-8072
    3 Faults Found:
    02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                 Freeze Frame:
                        Fault Status: 00111011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 25
                        Mileage: 185231 km
                        Time Indication: 0
                        Date: 2024.02.02
                        Time: 06:02:33
                 Freeze Frame:
                        Voltage: 12.30 V
                        Temperature: 10.0C
                        Bin. Bits: 00000011
    00870 - Bass Speaker Front Left (R21)
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 25
                        Mileage: 185231 km
                        Time Indication: 0
                        Date: 2024.02.02
                        Time: 15:58:25
                 Freeze Frame:
                        Voltage: 12.00 V
                        Temperature: 9.0C
                        Bin. Bits: 00000011
    00871 - Bass Speaker Front Right (R23)
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 25
                        Mileage: 185231 km
                        Time Indication: 0
                        Date: 2024.02.02
                        Time: 15:58:25
                 Freeze Frame:
                        Voltage: 12.00 V
                        Temperature: 9.0C
                        Bin. Bits: 00000011
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000344306
       Coding: 0001103
       VCID: 5EE4998E6C363C7A7DF-800A
    1 Fault Found:
    02752 - Glovebox Unlocking Motor (V327)
                010 - Open or Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Status: 00101010
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 22
                        Mileage: 185256 km
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 12.000 V
                        Temperature: 77.0C
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
       Component: TSG BF          H12 0210
       Revision: 00000000    Serial number: •˜
       Coding: 0003610
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 5
                        Reset counter: 26
                        Mileage: 185374 km
                        Time Indication: 0
                        Date: 2024.02.06
                        Time: 12:18:45
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000511
       Shop #: WSC 02324 758 00200
    Address 56: Radio        Labels: Redir Fail!
       Coding: 0540002
    1 Fault Found:
    00856 - Radio Antenna
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 22
                        Mileage: 185256 km
                        Time Indication: 0
                        Date: 2024.02.04
                        Time: 12:22:36
    Address 61: Battery Regul.        Labels: 4F0-910-181.clb
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: J0644 BEM       H12 0590
       Revision: 00000000    Serial number: 00000000125016
       Shop #: WSC 00763 210 80270
       VCID: 2312E87A07D45192121-8076
       Subsystem 1 - Part No: 4F0 915 105 D
       Component: von VA0  2708010899
       Coding: 344630393135313035442056413032373038303130383939
       Shop #: WSC 00000 512 00290
    2 Faults Found:
    02254 - Interface to Generator
                 Freeze Frame:
                        Fault Status: 00110100
                        Fault Priority: 4
                        Fault Frequency: 89
                        Reset counter: 243
                        Mileage: 185211 km
                        Time Indication: 0
                        Date: 2024.01.31
                        Time: 14:35:09
    02479 - Partial Consumer Shut-Off Active
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 73
                        Reset counter: 255
                        Mileage: 185214 km
                        Time Indication: 0
                        Date: 2024.01.31
                        Time: 16:05:27
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
       Component: TSG HL          H21 0210
       Coding: 0003074
       VCID: 2E04094E5C16ECFA8DF-807A
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0210
       Coding: 0003074
    End----(Elapsed Time: 01:37, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
  2. Re: VCDS scan today, what does it all mean?
    133 Post(s)
    1987 Post(s)
    Which part bothers you?
  3. Re: VCDS scan today, what does it all mean?
    Mar 2024
    Ireland
    hi, im a newbie here andjust replaced egr valve on my a4 ,all went well until a few days ago when mil light came on scanned with vcds and got these faults, car is going well and not in limp mode . fault keeps coming back after clearing, just wondering is my new egr valve faulty. Any help would be great.Scan-WAUZZZ8K9BA099080-20240229-2037-153670km-95486mi.txt
  1. VCDS Scan
    By as400 in forum Golf MK6 - 2009 - 2013
    Last Post: 18-02-2022, 10:00 AM
  2. Vcds scan, faults, help
    By Deividas0523 in forum VCDS - General Questions
    Last Post: 12-02-2017, 10:02 AM
  3. First Vcds Scan
    By JohnFA6 in forum VCDS - General Questions
    Last Post: 02-05-2015, 09:07 PM
  4. sheffield vcds scan please
    By swally34 in forum VCDS - Help Requests
    Last Post: 14-08-2013, 07:32 PM
  5. VIN not displayed on VCDS scan?
    By vdubgolf in forum VCDS - General Questions
    Last Post: 27-06-2012, 07:08 PM
